Was watching tv and it just went off. I unplugged it to try to see if that would help after pluggung it back in and nothing. it just clicks and tries to come on, but no picture or sounds.???
Thirst thing to try is take the batterys out of the remote and push all of the buttons to get any electric static for say 3 to 5 minutes if that don't work try to see if your remote signal works by using your iphone and take a few photos of the remote beam when pressing ,or the remote in the tv might have gone. Ps happened to me
the photon charges at the back of the tv might be damaged, try to take it in to be repaired if not i suggest u buy a new one, please, please, please do not take it apart to fix it urself, alot of bad burns have happened to people who try to fix plasma tv's.
Try this before calling a factory authorized service center:
Press " menu 2 > 4 > 7 > 0 > enter", on remote. After settings have been initialized > press the system reset button on the front, once the LED stops blinking > reprogram settings and tuner channels (if not using box). IF NOT fixed call for service (get estimate before repair) and suspect repair of DM PCB (printed circuit board).
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
it is a symtpom of vertical failure in circuit..its either loose connected part or blown up ic in vertical section but most of the time its just a dried up capacitors 100uf/50v 1000uf/25 and 2 2.2uf/50v
