Whenever 3.75g hsupa modem is plugged, it requests for user name and password
SOURCE: Rest password on DNA-A211-I ADSL2+ Modem
hi..
the only way to restore the router is to hard reset the router,which will reset the router to the factory defaults and then setup the router as the first time installation and the default username and password will be restored,i kno this is much of a work to reset the router and again setup the router like 1st time installation but this is the only way to retrieve the default user name and password..
vedhick
SOURCE: 192.168.0.50 not asking for user name & password
Well, if that does not work then perform the below task to check for the correct IP address that you need to have access to:
# Connect your computer directly to your wireless router and perform the following tests.
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here. Also, mail us the same IP configuration.
Now on your browser type the IP Address as saw in default gateway. This should work.
Regards
Anand
Testimonial: "Very helpful information. Thanks."
Press and hold the reset button of the Linksys router using a pointed object (like a paper clip or pen) for 30 seconds.
The reset button is located in the back of the Linksys router closest to an Ethernet port.
The button is recessed to protect you from accidentally resetting the modem.
Unplug the Linksys router while pressing the reset button.
Shut down your computer for one minute.
Plug the Linksys router back into the wall outlet.
Reboot your computer.
Open your web browser to access a website.
Type the below in the address bar if you want to reset your password:
http://192.168.1.1
A prompt from the site will request a user name and password.
The user name stays blank, or, in some models, is "admin".
Navigate to the security tab. Input your new password to protect unauthorized access to your router
hope this helps
i mistakingly deleted the instalation drivers for this my modem with Model: MF631 HSUPA USB STICK and IMEI: 359538033590695. anytime i insert the modem on my laptop it kept showing new hard ware found and could not complete the hardware installation. plase help me
