Have green light its not igniting not sure if its on timer
Sounds like an old boiler. It is not on timer and has to be lit manually. Push in the gas button and hold and push the sprung ingnition button to greate spark. Continue to hold in gas button 1-2 mins and release. The pilot light should then stay on. The flame will have heated the sensor in the combustion chamber and the boiler thinks that there is a flame and will allow the main gas jets to light when demanded . If the flame does not stay on clean the sensor prongs with emery cloth but do wait until they are cooled. You have open up the combustion chamber for access
The 1-2 mins above varies
SOURCE: hi, my ideal combi boiler mini HE C24 has lights
could be your microswitch check overheat stat and fan are o.k. best of luck
SOURCE: Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
SOURCE: pilot light on boiler
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
SOURCE: I have a Sime Super 90 Combi Boiler. How do I
does it have a little red button on the right hand side of the gas valve? if so you must put the gas valve button in the pilot positon and push it down and hold it, then click the red button {push it down} it will click and look at it keep clicking while holding down the button on the gas valve eventually when the gas gets thru it will light could take several clicks of the ignitor
SOURCE: how do you light a ravenheat pilot light
push in the yellow or grey button on the gas valve and click the piezo ignighter repeatedly keep the gasvalve button depressed for 20 seconds and the boiler should light if it does not you have a fault come back for more advice if this happens
