Even though the plastic cub like casing is cracked it would appear that the seal around the piping on the outside of the tub also leaks. I am concerned about the others cracking as well. What I don't understand is why the plastic would crack. I had a tub with jets for 20 years and never had a problem. This tub is only 6 year old.
Cheap plastic fatigues with heat . Silicone will work but will not keep the crack from continuing. The fix depends upon what type of plastic you have . It is likely a polyester like fiberglass in which case you can use regular fiberglass to fixit . Rough up the outside with 80 grit , brush in fiberglass resin ( don't forget to mix in hardener) lay in glass material , repeat until built up . Repair the front with a good "gelcoat " repair kit which allows you to mix match color.. sand with 220 , then 600, then 800, then 1500, then 3000 , polish with automotive whit polishing compound , wax
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
SOURCE: cracked housing to underwater tub light
I belive but am not positive that those lamp assemblies are required to be low voltage. In other words, there is no safety issue if water contacts the builb or wiring. Call Americh to verify. The lens ought to be easily replaceable so as allow for bulb replacement. Ask Americh.
SOURCE: HELP!!! I need bubble
Hi.
Contact Vitabath using the links below:
Vitabath Homepage
Vitabath le Chateau
Or call 1-305-685-5739
Alternatively use this form to locate a dealer that can source the part.
Regards.
Ginko
SOURCE: I have an American Standard
This may be a silly question but, have you tried to, as much of a pain in the **** as it is, tried to look through your, hopefully accsessable acsess panel to see if you can see the leak. I understand that it could be getting out around jets but, there are so darn many places it could be leaking. If you have inspected the jets and they seem to be sound and flush, I'd look elsewhere, for instance, how often, if ever, does the water get to the overfow? They can leak around their seal and sometimes will not be tightly seated. A question I have for you is, do you have drywall or something on the ceiling in your basement and, if so will you be taking it down because of leak. If you have planked floors, you may be able to get an idea, not guaranteed, of exactly where it is leaking which, could let you know which side of the tub the leak is on, hopefully, the one you can see. If it's not on the side you can see, and is a planked floor, you may be able to cut you a little access hole in the ceiling of basement, floor under tub. to see. This may or may not work depending on how the tub was framed and installed but, you would obviosly know where the drain is and could use taht for reference. Anyway, the rings of the jet will come out but, I would give them a good inspection and, if they look sound, it could be something else. How bad of a leak is it and, how long does it take for the leak to show up in the basement?
