I need a radio code for my 1999 acura TL.
You must contact the parts department of your local Acura dealer to get this code. You will need to show them your car's registration to prove that you are the owner. You may be able to get the code with only the registration and the VIN code (found on the registration). Some manufacturers require the serial number on the radio, which would require that the radio be removed from the car to see the serial number.
Charlie
Press the numbers 1 and 6 then press the power button this will then show your radios serial number on the display. repeat and press 2 this will tempo. give you tunes.. get the serial number and call dealor. Hope this helps.
SOURCE: Code P0505 on 1999 Acura TL
this code make reference to low idle engine,maybe the throttle body is dirty , air filter clogged, vacumm leak , pcv valve clogged, check for thoses
SOURCE: Security code for my 1999 acura TL stereo system
please tell me the security code for the fordfalcon year model 2000
Radio lock out codes are security related to discourage theft, so they are not published on the internet, if they were what would be the point?? any thief could get the code after stealing your radio. Contact the dealer for instructions an what info u need to get your cars unique radio code.
