Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
Posted on Jun 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Homelite weedeater smokes
Does it smoke because of too much gas in the mixture or not enough gas in mixture
Jim Parker
Level 3:
  • Master 1,041 Answers
  • Posted on Jun 16, 2009
Jim Parker
Master
Level 3:
Answers
1041
Questions
5
Helped
536326
Points
2636
Yes, you have too much oil in the gas.
Jim
  • Jim Parker
    Jim Parker Jun 17, 2009
    Thanks for the rating
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
I put seafoam in my weedeater with on mixture of gas and oil and it runs better why
It can get its air easier. When using too thick an oil in the filter, sometimes the carby cant breathe properly and it will cause the motor to stall.
What is the proper gas / oil mixture? It smokes bad on a 50:1 mix.
Try 30:1 mix that should fix the smoke problem.
Thank you for using Fix Ya.
What is the gas oil mixture for a homelite ut20721 trimmer
Try a 50:1 mixture first if that is too rich,as in white smoke comes from the exhaust,then use a 30:1 mix.
Chain saw ran for a few minutes became hot with little smoke and now will not start again.
It could get hot and not start if the saw was quite dirty because it relies on air for cooling and if the fins can't get enough air around them it would heat up and not start. Another thing is if some one did not use the correct gas oil mixture it would get hot and score the cylinder lowering the compression causing it to not start.
1helpful
1helpful
My redmax eb7001 emits white smoke while running, the more power...the more smoke
Your fuel-oil mixture has too much oil in it. The standard ratio is 40:1 which means one of the little bottles of 2-stroke oil (about 2.6 fluid ounces) is added to 1 gallon of gas. Homelite recommends a 50:1 ratio but 40:1 is better, at least in my opinion.
The last time you made the mix, did you pour the oil into the gas or did you pour the oil into a little bit of gas in the gas can, shake well and then fill it with a gallon of gas? The former can give you lots of smoke as well because it is not mixed thoroughly. The latter is the best way to mix because the agitation and the flow of gas mixes the oil better.
Other possible causes to this problem are: how old is the mix you are using? Did this mix sit all winter last and you sre using it now? If so, did you add some Stabil to the mix before storing?
Depending on your answers to the above questions, you can determine why you are getting so much white smoke.
My recommendation to you is to:
(a) Empty the blower gas tank.
(b) Mix a fresh batch of oil and gas in an approved fuel container.
(c) Pull the spark plug and inspect it, if it is black/sooty replace it.
(d) Pour the new mix into the tank and start the blower.
This should get rid of the excess smoke, if it doesn't, let me know here. Good Luck!
15helpful
Gas/oil mix
Most trimmers are using a 50:1 mix. 2.6oz/gal or 6.4oz/2.5gal. A 4oz/Gal is a 32:1 mix which way too oily and you will have problems of excessive smoke, oil leaking out muffler, carbon buildup causing sticking piston ring or a clogged spark arrestor.
12helpful
3answers
1helpful
Oil Mixture
If it's not stamped on the fuel cap the I would try 50:1 if it smokes a little cut it back to 32:1 its always better to start with a higher mix when not sure any smoking is just the excess oil burning off in the muffler. It's better to have to much oil than not enough when it comes to 2 stroke engines.
Mar 14, 2009 • Garden
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
