Question about Microsoft Windows XP Professional
An uncepted error occured at line 1773 in d: - Microsoft Windows XP Professional
4 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: Vista An unexpected error (1342140992)
Be sure to run the upgrade advisor:
http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx
Sometimes this can pinpoint any problems that will arise. The requirements for Ultimate are different from Vista Basic.
How far are you getting on the install or is it breaking before it even starts to install?
Posted on May 12, 2008
puertobori
  • 7733 Answers
SOURCE: An unexpected error (1129072392) occured line 1773
go to LINK.
Posted on Oct 23, 2010
Holygrass
  • 443 Answers
SOURCE: "Unexpected error (0) occured at line
Hi Ghosh.
Cause of this problem may be:
This behavior can occur because of damaged random access memory (RAM) modules or a damaged RAM slot.
To resolve this issue, use one or more of the following methods, as necessary:
  • Remove one or more of the RAM modules in your computer, leaving at least the minimum amount of RAM required for Windows XP installation. If this resolves the issue, either replace these modules with new RAM modules or reinsert them after Setup is completed.
    NOTE: Verify that your computer's performance is not affected when you reinsert the old RAM modules.
    -or-
  • Install the RAM modules into different (unused) RAM slots in your computer.
    -or-
  • If you still experience problems before or after Setup, replace all of your computer's RAM modules with new RAM modules.
Posted on Dec 22, 2010
What is error code E000110-0105 for a Canon imageRunner C4080 copier?
Hello Sir,
This error is about yellow laser unit:
Your error code translate:
E000110 = Polygon Error
0 1 0 5
1st line: Always 0
2nd line: Station where the error occurred (1: Y, 2: M, 3: C, 4: K)
3rd line: Main unit status when the error occurred (0: Activating, 2: BD control 1, 3: BD control 2, 4: Changing the speed, 3: Operating steadily)
4th line: Polygon control status (0: Suspension, 1: FG rotation, 2: BD control 1, 3: BD control 2, 4: BD Control 3, 5: BD control 4, 6: Phase locked)
In most cases you need to replace laser unit, but first, you need to check all the connections between electronic board and laser unit.
Best Regards,
Mar 27, 2015 | Canon Office Equipment & Supplies
Hi Ghosh.
    -or-
    -or-
Dec 22, 2010 | Microsoft Windows XP Professional
I having a promblem trying to load o/s,it start well to load but after just a moment before it coping files it gives me an error 1773
Error 1773 error symptoms can include slow PC performance, program crashes, system freezes, startup/shutdown problems, and file errors. Risks that can result from not repairing your computer include blue screens, file corruption, and hardware failure.
Fixing Error 1773 is easy. Download and install PC Health Advisor, a Microsoft Windows tool that will analyze your registry for missing, obsolete, and corrupt entries resulting from failed installations, incomplete un-installations, disabled drivers, and spyware applications.
Nov 09, 2010 | Computers & Internet
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
Windows xp setup halts
This generally indicates that the disc is corrupt. It can be anything from a scratch, degraded read section on the disc, or a distortion from the disc getting bent or hot (left in direct sunlight). You will most likely have to use a different disc for the install.
Sep 03, 2008 | Toshiba Satellite A65-S126 Notebook
I dont know what the error actually means.
But have you formatted the hard drive using NTFS.
Are you selecting the upgrade option.
To perform the installation follow the steps :
http://support.microsoft.com/kb/918884
Use the vista upgrade advisor whether your compter is capable of upgrading to vista.
Then start the installation.
Good Luck.
Live, Love, Laugh.
May 03, 2008 | Microsoft Windows Vista Ultimate Edition
I Can't Install Windows XP Operating System on my AMD Sempron Computer
cheak ram clean disk ? try one ram do partion on hard drive del it then make new one then slow formatt then install ok and update call it in
Jan 18, 2008 | AMD Sempron 2400+, 1.667 GHz (sda2400box)...
Reformating
Insert windows XP and boot from cd and it will ask u Press any key to start from CDRom and repartitioned ur hard disk and reinstall it by using NTFS Partition
Dec 31, 2007 | Computers & Internet
Microsoft Windows XP Professional Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
