Try removing the toner cartridge and gently cleaning the electrical contacts for the sensor. Sometimes they get toner residue on them and give false readings.
That is a fuser fault. Can be caused by dirth thermistors on the hot or pressure rolls.
Can be a bad heat Rod. But on a 450, It is almost likely a bad thermistor. It is the flexable temperature sensor that rests on the hot roll to monitor the temperature.
fuser temperature problem code.IF YOUR MACHINE IS A RICOH,SAVIN.
GESTNER, OR LANIER YOU CAN TRY TO CLEAR IT YOURSELF.PUSH
YELLOW CLEARALL BUTTON THEN ENTER 1,0,7.STOP HOLD THE STOP BUTTON DOWN UNTIL THE SCREEN CHANGES ABOUT 3 SECONDS.PUSH THE ICON BOX THAT SAYS COPIER SP A NEW SCREEN WIIL APPEAR DO NOT TOUCH IT. TURN THE MAIN POWER
SWITCH OFFFOR TEN SECONDS.THE MACHINE WILL ATTEMPT TO
RESET AND WARMUP PROPERLY IF CODE COMES BACK YOU WILL
NEED SERVICE ABOUT 200.00 FOR FIRST HOUR PLUS PARTS IF NEEDED
Try opening up your web browser and type in the ip address of your lanier. You should to access the facsimile function located on the left side. Once youre in the facsimile function, you should see a thumbnail view of the faxes stored in your lanier. Simply click on the faxes and delete them.
did you turn the dial to light the display? if so the back lights are out on the display or the ballest is bad. you need to replace the diaply. have a tech come out.
