Computers & Internet Logo
E
Eugene swanepoel Posted on Apr 07, 2014
L6EV6RH6CA000 I need model of this Com switch
2answers
Purchase a door push button switch for my refrigerator
Visit a local appliance repair shop or parts store that specializes in refrigerator parts. Bring the make and model information of your refrigerator to ensure you get the correct switch. They can assist you in finding the right door push button switch for your specific refrigerator model.
NEED A REPLACEMENT Switch FOR TECHKO MODEL SH6010CP shredder. MY SWITCH HAS FAILED.
Please don't include email addresses. This site get 11 million views a year. How many do you reckon will email you every day for a chat.
And please don't type in all CAPITALS. I is considered shouting and is hard to read!
There is only one place that does Shredder spares. They are considered a disposable item.
https://shredderparts.com/techko-parts/
more here
https://www.google.com/search?q=TECHKO+MODEL+SH6010CP%2C+REPLACEMENT+Switch
3answers
Cub lgtx 1050 dies when clutch released
https://www.youtube.com/watch?v=TO_bhdka3_c
Apr 04, 2020 • Garden
2answers
Why do I Sometimes have to use pull start now?
you'll have to break out a meter and start checking things. could be a starter switch, starter relay or just needed a starter rebuild. also if your bike has safety switches like brake handles, clutch and nuetral switches check all them.
1helpful
How do I get top of my washer..Maytag Centennial ...Model # MVWC400VW1...to get to the lid switch?
This model Maytag is actually manufactured by Whirlpool. To access the lid switch on this particular model, all you should have to do is remove the operator console. The console has a retaining clip on each side holding it to the cabinet top. To release these clips, simply take a putty knife and slide it under the left and right front corners of the control panel push straight in towards the back of the washer. The clips will depress, allowing the operator console to be lifted up. The lid switch is mounted next to the left lid hinge. Refer to the "Top and Cabinet" parts illustration, Item 6 at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWC400VW1/3048/0153200?pathTaken=&prst=0&shdMod=MVWC400VW1
Some other websites you may refer to for parts include:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: If you model number does not cross reference to these sites, use the part numbers fromthe Sears websites as your search criteria. Often, the model numbers may not be included on some websites (newly added models), but the part numbers will.
HINT: In some cases, what may appear to be a bad lid switch, may only be an actuator adjustment. The acutator on these models is the rod attached to the left lid hinge. You can bend the rod slightly to adjust the contact with the lid switch, or it may be tightened as necessary. If the switch toggles (clicks) by hand with the actuator rod removed, the switch typically is not bad.
If you need to remove the entire cabinet to access under the lid, the following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If you need further assistance, please post back and let me know. I hope you find this information helpful.
2answers
Kenmore Model 27831600 - How do you get to the lid switch? Evidently it has come loose and is not working properly.
First unplug unit ..You will need a fairly stiff putty knife, you need to remove the upper console to gain access to the lid switch, push your putty knife straight in towards the back of the unit one at a time under each end cap of the control panel afteryou have popped loose the clips you can flip open the console and you will see the lid switch on the back left hand side .Its just snaps in place..Tip before doing any of this make sure the 2 small screws are completely tight that attach the lid to the left side hinge because this is also the arm that actuates the lid switch .. Writing it out makes it sound way more complicated than it is ..Its really a 5 minute job Good Luck
Door switch needs changing
There are videos at www.appliancehelponline.com/servicemanual.html that will walk you replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Canal rh series need on switch replaced model
ZE-235L can be used to replace Canar RH series switche. You can find it on this link:
https://www.ceilingfanswitch.com/product/zing-ear-ze-235l
6helpful
4answers
Need to replace d3v-16g-3c25 for my sharp micro...where can I get it... .1 amp 124v dc
That sounds like a door switch. Which switch is it? Top, middle, bottom?
Is your model number R1480? If not, please reply back with your model number so we can help you.
The door switches in model R1480 are:
QSW-MA110WRE0 top & bottom switches
FFS-BA016/KIT middle monitor switch with fuse (kit)
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
But the best place to order Sharp parts is Tritronics.
If none of this info helps you, please reply back with your brand and model number and let me know which part you need.
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
