Sylvania 6432GG 32" TV Logo
r
rolly jamilla Posted on Apr 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Always blowing fuse in my astron tv..why?
Astron tv 14 blowing fuse every time that i swicth on...
Tomislav Marinovic
Level 2:
  • Expert 205 Answers
  • Posted on Apr 07, 2014
Tomislav Marinovic
Expert
Level 2:
Answers
205
Questions
0
Helped
77213
Points
569
It is possible that the fuse is damaged (if it is an automatic one). They are prone to damage after first shortened circuit. Try to plug in your tv elswhere and see if the issue repeats itself.
I need a code for keyin rm 167e astron tv
The universal remote code for Astron TV can be programmed using the following list of codes:
672
673
075
094
091
000
0048
0042
0041
To program your universal remote to work with your Astron TV, follow these steps:
Aim your universal remote toward the Astron TV.
Press and hold the "SET" button until the small light on the remote control illuminates.
Enter the remote code using the numeric keys.
Upon entering the correct code, the remote light will turn off.
For Astron TVs, the Chunghop universal remote is recommended due to its compatibility and easy programming. Alternatively, you can try a GE universal remote, but you'll need to program it without specific codes.
If you encounter any issues with your Astron TV remote, such as it not working, consider resetting it to factory settings.
2answers
Burning mode on astron led 3277
Try pressing the input or source button on the TV continuously for 5 seconds.
How come netflix does not work on my Astron TV. What shall I do?
The following Astron LED 32 TV was advertised with built-in Netflix capability. https://shopee.ph/ASTRON-LED-32-TV-(brandnew)-i.118118557.4007371447
Changes in Netflix rendered current software versions incompatible with older sets. And here is a reference regard some 2010-2011 Samsungs being incompatible: https://www.bbc.com/news/technology-50331667
If your Astron's support is unavailable, an alternative is to try casting from your mobile device to the TV. https://help.netflix.com/en/node/49
https://www.astronelectronics.com.au/
How to enter service mode astron tv model 14/17/21/25/29
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
I have astron tv 14 inches. when i connect outdoor antenna the. tv screen turn black. no signal. no reception but when i disconnect the outdoor antenna it turn to blue screen.
blue screen means 'no signal' or 'signal level is too low' whereas black screen means that there's a signal. Check your antennae, do a factory reset to your unit and then try initial setup.
When i turn on my astron 14 tv after a few sec. The screen will indicate factory settings and then it will turn off automatically
Check for sticking buttons on TV. And the remote, remove the batteries, at least that will eliminate the remote,,,hope this help
What is the remote code of astron 14"
0048,0042,0041. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electromedicals.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
4helpful
How to remove the lock 0f astron tv
Press Program > and Program< buttons on the front panel of the TV simultaneously for more than 3 seconds.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
