HI. My Camcorder has built in Memory and card which is installed 64GB, class 10. these or TWO Individual Memory's can you tell me how I can retrieve my Photos from the Built in one do I need some sort of mini usb cable.
SOURCE: How to transfer the video in Mini DV to my computer
I suggest getting the PCI IEEE 1394 also known as FireWire card. Most of the time these Firewire card comes with a Video editing software but verify because you will need some form of video editing s/w to record the video. After recording then you can edit it however you like and transfer to DVD/etc. Always a pain in the as to edit video. I've done it a couple of times. So have fun. I still have not manage to find a Video editing s/w that will do a 5.1 audio or multiple audio tracks (similar to switching between languages)
SOURCE: jvc gr-d395u video camcorder, move mini dv to computer
How it's supposed to work is to get a program that recognizes the camera, then the tape can be captures. Windows Movie Maker never supported it. In fact Microsoft doesn't even support it anymore. They have recommended using Pinncale Studio to work with DV cameras.
Once you install Studio, put the tape in, turn the camera on, Studio will load up.
SOURCE: memory format problem
First of all, check the lock button on the side of your sd card to make sure it's not in the lock position. If it's unlocked and you still cannot format the card, you can always format it on your computer via usb.
SOURCE: I need to buy a memory card for my JVC GR-D270U
you can add an SDRAM card. Goes right next to the battery. they are very inexpensive.
SOURCE: How to use an SD card to record on a JVC GR-D370 mini DV?
Download PC Inspector File Recovery.Thank
