Konica Minolta bizhub 350 All-In-One Laser Printer Logo
A
Anonymous Posted on Apr 07, 2014
Mac address for bizhub 161f
I have link lights on NIC but when printing a config page it reports there is no NIC installed. I have reset device back to factory defaults. Is there some other way of finding the MAC / hardware address of the device?
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 10, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913926
Points
11960
Are the print driver installed properly was a ip address given to the machine
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • 167 Answers
  • Posted on Jan 08, 2008
SOURCE: Bizhub C250
In the Utility Menu you can set the default settings for most functions. Set the copier to the state you wish it to be in. Under the utility menu there is a default setting button. This will allow you to set the current state to the default as well as reset to factory default.
Anonymous
  • 167 Answers
SOURCE: C252 Mac issue
You need to set the options in the printer driver as well. You need to tell it just what features you have installed on the device.
Anonymous
  • Posted on Jun 19, 2008
SOURCE: I cant install konica Minolta bizhub C351 on my mac. please HELP
To print via IP on MAC  type IP address in queue type print ,name the printer and  the correct driver/ fy...35/
Anonymous
  • 62 Answers
  • Posted on Jan 29, 2010
SOURCE: c14a3 error code konica minolta bizhub 161f
Hi jdt_mk,
Sorry to hear you have a C-14a3 code.
In my experience, this code spells disaster for the 161f.
The image reader has failed. The part can be replaced, but the cost would almost outweigh the cost of replacing the machine.
I have personally had to deal with two 161f with the same code.
Both times we changed the machine (because it was on contract).
Sorry it's not good news
Anonymous
  • Posted on Apr 29, 2010
SOURCE: konica minolta bizhub c350 installer for mac
You have to have a fiery unit (external controler) to use the C350 With a Mac because the c350 dosnt come with appletalk in the software. IC-401 Is the model number of the controller you will need to connect the c350 to any kind of mac for printing / scanning.
2helpful
2answers
I have an HP Lasejet 1320 printer and I am trying to reset static IP Address as we are moving from one network to another. I need to know how I can determine the mac address of the printer as I can...
To find the static IP and Mac Address of your printer, press and hold green button for 10 seconds until green and yellow light starts blinking together, it will take out 3 print outs, 1 is printer information, 2nd will be configuration page, 3rd will be the toner status page,
Also you can Check your printer manual. This is the easiest and fastest way to find the printer's MAC address
Alternatively Print out a configuration page.
If you require more assistance, feel free to reply to this post
Thanks for Asking FixYA!
Regards, BA
10helpful
5answers
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
I get a black line through the copy on the Konica Minolta Bizhub 160. How do I fix it?
if you print a report and there is no line its the adf **** glass so clean it with a rag and glass cleaner
4helpful
2answers
Can't find the mac address on a brother laser printer 2170w
page 66 of the network users manual explains how to find the mac address on your printer, you have to print out a test page from the printer and it should give you the info, still get the manual so you can read up more on network settings:
http://www.brother-usa.com/manuals/default.aspx?PGID=1&R3ModelID=hl2170W
Download the manual and make sure you have adobe reader installed on the computer.
2helpful
2answers
NetGear WGR614 -Installation Problem on Windows Vista PC
Please make sure that you have the NIC enabled and on the computer and set to automatic settings for IP address. Now follow the steps below to reset and reconfigure the router:
Reset:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
46helpful
Printer's MAC address
Hi!
I was able to locate this information for you on tht Toshiba FAQ section of their tech support site. Here is it, verbatim:
How do I discover the MAC address of the Brother network card?
To discover the MAC address of your Brother network card you will need
to print out a Network Configuration Report. To print this report
complete the following steps:
1. On the Brother machine press MENU.
2. Use the up or down arrow key to scroll to PRINT REPORTS and Press OK.
3. Use the up or down arrow key to scroll to NETWORK CONFIG and Press
OK.
4. Press BLACK START
5. The Network Configuration report will print. On the report, find the
section labeled <(><<)>Ethernet Address>. (Example: <(><<)>Ethernet Address> 00-80-77-90-0a-8c) This is the MAC address of your
Brother network card.
1helpful
Konica Bizhub's Trays
You will need to go to the printers folder under Start, settings, & select the C252, right click on it, select properties & go to the 'Option' tab.
In here input the C252's IP address into the 'printer name or IP address' field and select gather option information.
Once done you will need to apply the settings and ok.
If you dont know the IP address you can get it by going into Utility, user settings, print reports, config page.
You should now be able to select the correct trays without errors.
Hope this Helps.
6helpful
3answers
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
4answers
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
