Computers & Internet Logo
Eve Moore Posted on Apr 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Osd wont go away from screen - Computers & Internet
pankaj rautela
Level 3:
Genius:
  • Master 1,252 Answers
  • Posted on Apr 07, 2014
pankaj rautela
Master
Level 3:
Genius:
Answers
1252
Questions
0
Helped
333557
Points
3358
Its the problem of your display panel, check whether some keys struck or not
Why is there a white vertical bar down the middle of the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
2answers
Monitor display says OSD Lockout /no signal input how to fix this?
This document pertains to LCD monitors .
One of the following messages appears on the screen (over the items being displayed).
OSD Lockout
OSD Lock-out
... or similar message.
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
2helpful
An OSD message appears in a box that covers much of the monitor screen. The mouse pointer disappears behind the box whenever I try to sweep into it. The box will not go away (except intermittantly)...
OSD means On Screen Display. To unlock the OSD hold the power button of the monitor until you get a message similar to "OSD unlocked".
If you still have problems, click on this link for further instructions :-
http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
4helpful
Ocd lockout
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
6helpful
Osd lockout
I hope it helps.
All the best.
3helpful
3answers
The sceen say`s osd lock out and also the menu screen for the monitor is stuck on . The menu,+,- and auto set buttons wont respond
OSD Lock-out — The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message “OSD Lock-out” appears for 10 seconds.
If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
1helpful
3helpful
4answers
OSD lock out
I HAVE AN OSD LOCKOUT ON MY SCREEN WHICH BRINGS UP THE MAIN MENUE. THE MOUSE DOESNT WORK ON IT TO SWITCH IT OFF!!
Flashing osd
It would help to know what the OSD says; is it a message from the monitor or from the main system?
Grand Canyon Tech
Grand Canyon Tech
