Application.FileSearch
'!!! Replacement solution including searching in subdirectories !!!!
Sub FileSearchByHavrda_Example_of_procedure_calling()
' Example of FileSearchByHavrda procedure calling as replacement of missing FileSearch function in the newest MS Office VBA
' 01.06.2009, Author: P. Havrda, Czech Republic
Dim FileNameWithPath As Variant
Dim ListOfFilenamesWithParh As New Collection ' create a collection of filenames
' Filling a collection of filenames (search Excel files including subdirectories)
Call FileSearchByHavrda(ListOfFilenamesWithParh, "C:\Temp", "*.xls", True)
' Print list to immediate debug window and as a message window
For Each FileNameWithPath In ListOfFilenamesWithParh ' cycle for list(collection) processing
Debug.Print FileNameWithPath & Chr(13)
MsgBox FileNameWithPath & Chr(13)
Next FileNameWithPath
' Print to immediate debug window and message if no file was found
If ListOfFilenamesWithParh.Count = 0 Then
Debug.Print "No file was found !"
MsgBox "No file was found !"
End If
End Sub
Private Sub FileSearchByHavrda(pFoundFiles As Collection, pPath As String, pMask As String, pIncludeSubdirectories As Boolean)
' Search files in Path and create FoundFiles list(collection) of file names(path included) accordant with Mask (search in subdirectories if enabled)
Dim DirFile As String
Dim CollectionItem As Variant
Dim SubDirCollection As New Collection
' Add backslash at the end of path if not present
pPath = Trim(pPath)
If Right(pPath, 1) <> "\" Then pPath = pPath & "\"
' Searching files accordant with mask
DirFile = Dir(pPath & pMask)
Do While DirFile <> ""
pFoundFiles.Add pPath & DirFile 'add file name to list(collection)
DirFile = Dir ' next file
Loop
' Procedure exiting if searching in subdirectories isn't enabled
If Not pIncludeSubdirectories Then Exit Sub
' Searching for subdirectories in path
DirFile = Dir(pPath & "*", vbDirectory)
' Add subdirectory to local list(collection) of subdirectories in path
If DirFile <> "." And DirFile <> ".." Then If ((GetAttr(pPath & DirFile) And vbDirectory) = 16) Then SubDirCollection.Add pPath & DirFile
DirFile = Dir 'next file
Loop
' Subdirectories list(collection) processing
For Each CollectionItem In SubDirCollection
Call FileSearchByHavrda(pFoundFiles, CStr(CollectionItem), pMask, pIncludeSubdirectories) ' Recursive procedure call
Next
End Sub
