LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
A
Anonymous Posted on Apr 07, 2014
How do I install a new lg ru 52sz61d projector bulb in tv
4 Related Answers
Anonymous
  • 5 Answers
  • Posted on Jan 13, 2008
SOURCE: Replacement bulb LG RU-52SZ61D
VERY EASY UNDO THE SIDE COVER NOT THE BACK CASING UNDO THE LOCKING SCREWS AND BOBS YR UNCLE VERY EASY DO NOT TOUCH THE FRONT OF GLOBE WITH YOUR HANDS
CHEERS WOODY
ismash55
  • 138 Answers
  • Posted on Jul 23, 2009
SOURCE: Won't turn on with LG RU-52SZ61D 52 in. Rear Projection HDTV
The bulb you are buying is not the origianl one. The life of you bulb is too short, probably it was use before. Buy a original bulb and new.
Anonymous
  • 4234 Answers
  • Posted on Dec 17, 2009
SOURCE: I have a 60 inch LG t.v. that needs a new bulb
The part number for the lamp is: 6912V00006C
It can be purchased from tritronicsinc.com for $199.00 plus shipping.
Dan
Anonymous
  • 8197 Answers
  • Posted on Aug 27, 2011
SOURCE: How do I switch the
I just replaced the bulb/lamp on my LG RU-52SZ51D TV. It was fairly simple. Basically you have 2 screws that hold on the cover panel on the right side of the TV. Once you take off the cover, you'll then see a metal tray with a handle. That has 3 screws, you can then pull out the tray and see the bulb/lamp. The lamp has 3 more screws that hold the little brackets that hold the lamp in place. Last you have the 2 power wires. One is connected by a screw on the left of the lamp, the other is attached by a nut and a washer on the back of the lamp, where you would usually screw in a normal light. The two wires are just connected to a single plug to the right of the lamp which you can remove, you get the new lamp with the wires already attached. All you have to do is plug it in after you mount it back up. Here is the info on purchasing a lamp, sorry but I am still in the process of learning how to reset the lamp indicator light...
Website:http://www.partstore.com/ProductDeta...ModelID=491016
Zenith Projection TV Lamp
Zenith Part Number: 6912B22002C
LG Electronics Model: RU52SZ51D
Don't miss your favorite programs, keep an extra Zenith TV lamp on hand. NOTE: THIS PART IS MANUFACTURED BY OSRAM. IF THE OLD LAMP WAS MADE BY OSRAM, USE THIS PART.
Price: $ 273.83
Here is how to reset the lamp timer.
lamp reset on lge :to reset lamp timer press and hold ENTER or OK on tv display and MUTE on remote at the same time for 5 to 10 seconds, lamp reset box will pop up you can then reset lamp.
LG tv has no picture
Your lamp most likely failed. You can get a new bulb for it for less than $100. RU52SZ51D Bulb LG Genuine High Quality Original Projector Lamps now...
1helpful
How do I switch the bulb in a DLP projection TV model RU-52SZ61D
Price: $ 273.83
1helpful
2answers
Why is my light bulb sybol lit up orange
It's telling you your lamp is reaching the end of it's life you need to replace it.
1helpful
Purple band on tv dlp LG
Hi there
This is definitelly not your bulb.
Check if there is any damage to the colourdrum , if not then this is a faulty Mainboard.
Must warn you that LG's Mainboards are very expensive.
1helpful
CHEERS WOODY
RGB Input problem
Need assistance hooking up JVC VCR/DVD combo onto LG 52" DLP TV with Home Theatre System and Rogers HD PVR Box.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
