2003 Ford Expedition Logo
A
Anonymous Posted on May 24, 2017
My power third row seat don't work, I tested the motors and they work fine when power directly. When I measure the voltage at the connectors I get about +/- 10 volts, from any of the 4 switches. I verified the ground and it seams fine, I disconnected it and used a jumper cable from the ground directly to the battery ground, same result. Is there a different ground then G404 that I am not seing? Both seats go up and down smoothly when powered directly, I don't know what to look at next, any ideas?
Jeff Armer
Level 3:
  • Ford Master 15,575 Answers
  • Posted on May 24, 2017
Jeff Armer
Ford Master
Level 3:
Answers
15575
Questions
Helped
7111769
Points
73899
Your missing something's G-404 has nothing to do with it !
Seats - Third Row
The third row seat:
  • is three-passenger seat.
  • a 60/40 bench seat.
  • folds down for more cargo area.
  • has optional power fold down seats.
Third Row Power-Fold Seat
CAUTION: To prevent possible damage to the third row seat or the safety belts, make sure that the safety belts are not fastened when moving the seat to the load floor position.
CAUTION: Make sure that no objects such as books, purses or briefcases are on the floor in front of the third row seats or on the seat cushion before lowering the backrest(s).
The third row power-fold seat consists of the following electrical components:
  • right third row seat relay.
  • left third row seat relay.
  • right power-fold seat motor.
  • left power-fold seat motor.
  • right front third row seat switch (if equipped).
  • left front third row seat switch (if equipped).
  • right rear third row seat switch.
  • left rear third row seat switch.
For the third row power-fold seat to operate, a shared ground is supplied by the body security module (BSM) to both of the power-fold seat relays, enabling the seats to then be moved by pressing one of the third row power-fold seat switches. The third row power-fold seat operates only when the vehicle is in PARK and the liftgate glass, liftgate door or any entry door must be open.
The third row power-fold seat motors transfer movement to a drive gear assembly to raise and lower the seat backrest. The power-fold seat motors rotate a short drive cable which is connected to the drive gear assembly.
The relay's are located in Aux. relay box #2
  • bishop43 Jul 10, 2022
    Where is the left third row seat relay?
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Oct 02, 2008
SOURCE: Blower Motor on 2000 Saturn SL
The blower motor is connected to a termic switch, when the motor is fine and fuse is ok, is the switch that must be replaced.
Ensure the fuse is ok first.
Anonymous
  • 271 Answers
  • Posted on Nov 28, 2009
SOURCE: I have a electrical problem with 2002 Ford Focus
Check a conection cable between chassis and engine.Open and clean terminals.Put them back and check voltage.
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Mar 28, 2010
SOURCE: seat alhambra loss of power from third gear
could be turbo ,but the problem is its a common rail fuel injection system and this throws up another problem and that is its VW which from 2005 uses encrypted software so it is difficult to find the fault .change the fuel filter and see what happens if problem persists then its either a bosch diesel specialist or the dealer .sorry for no qiuck fix
Anonymous
  • 50 Answers
  • Posted on May 26, 2011
SOURCE: I have a 2003 Ford expedition Eddie bauer. Seat
The clicking noise sounds like your blend door actuator. Try turning your AC/Heat OFF and see if it stops (give it a minute to travel in position). The actuator is a common failure in the Expys, costs about $50 to replace. You will have to remove the right rear panel to replace it - a few screws and a couple of bolts (where the seat belt attaches).
As for the seat not working, not sure about this. I would make sure the wiring harness is hooked up and the fuse is not blown. See your owners manual for fuse location.
Jonah Oneal
  • 14092 Answers
  • Posted on Sep 19, 2012
SOURCE: My power single seat in the third row of my 2003 ford expediton won't fold down. I can hear the motor going. Is there a way of releasing manually so it will fold down?
mechanism lower seat driven by electric motor is broken.
Third row seat in 2010 Lincoln mkt will not work. Checked all the fuses and they are good.
Third row power seat relay , power fold seat module , third row seat control switch . Anyone of these could be the cause for the seats not folding ? With a electronic module involved codes could be stored pointing to the problem . Your best bet mite be to take it to a qualified repair shop.
Why is there no power to third row seat?
Power 3RD Row Seat Problems and Tranny Shutter - Ford Truck ...
www.ford-trucks.com > ... > Expedition & Navigator
Mar 27, 2014 - Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition andLincoln Navigator SPONSORED BY: ... First the 3RD row seats won't fold down, noclicking, no sounds, nothing. I the fuses are good and there is power at the fuse box, but no power at the motors or switches. Based on continuity ...
3rd row powerfold seat stuck down - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > 2007 - 2014 Expedition & Navigator
Mar 14, 2010 - 3rd row powerfold seat stuck down 2007 - 2014 Expedition ... 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator ... I also tried lifting the seat while my wife was pushing the button to raise it, to no effect. There is defnitelypower going to the motor but it just isn't ... Join Date: Feb 2005.
No power to third row seat on 2005 lincoln navigator - Fixya
www.fixya.com/cars/t12295627-no_power_third_row_seat_2005_lincoln
Apr 4, 2012 - no power to third row seat on 2005 lincoln navigator third row seat is ... U will have to replace the entire power seat transmission, there is no ...
Lincoln Navigator Review - Edmunds.com
Power windows and seats don't work
For seats problem,check the help links given below :----How to remove Seat on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-seat-on-acura-integra.html
Replacing power adjustable bucket seats to both heated and cooled seats? http://schematicsdiagram.blogspot.com/2011/12/replacing-power-adjustable-bucket-seats.html
----------How to Refit Rear seat? http://repairhelpcenter.blogspot.com/2012/01/how-to-refit-rear-seat-on-rover-600.html
--------How to Remove Rear seat? http://repairhelpcenter.blogspot.com/2012/01/there-are-3-10mm-bolts-at-back-of-seats.html
---------second row seat will not fold? http://technoanswers.blogspot.com/2012/01/ford-freestyle-second-row-seat-will-not.html
For all types of power window problem and power windows not working,i suggest you to go through the help links given below.Click the link to go through its procedure to troubleshoot the problem :------
Power window problem?
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
rear door or window will not open ?
http://technoanswers.blogspot.com/2011/06/rear-door-or-window-will-not-open-on.html
How to remove door panel, door window motor and regulator ?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
Power windows not working after car wash?
http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
---------power locks, power window and power mirror not working?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
-------------Complete Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
How to replace power window motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
-----------This will help.Thanks.
1helpful
2answers
2004 ford expedition: changed battery, now rear seats will not go up or down. One is up the other one is down. They were working fine before the battery was replaced. Wifes car need to fix, she is...
Call the dealership and ask them how to reset the electronic on your Ford Expedition after changing the battery. Anything else is happen? Maybe like the radio wont turn on, hit the turn signals and the windshield wiper turn on. ***** things happen after replace the battery. I know what it is, it the darn wigits. GB you....stewbison
1helpful
How do you remove the rear seat out of a 2001 Ford Excursion
If you are talking about the third row seat, the first step is to fold the seat down. Pull the lever behind the passenger side of the third row seat and fold the seat down. Then, from the cargo area, raise the bar located directly behind the third row seat and lift the seat forward. The seat should now be detached from the car and can be removed. When you reinstall the seat, be sure to secure the seat properly so passengers do not get injured in a sudden vehicle maneuver. This should help you to fix your problem. Contact me at FixYa if you have any further questions.
14helpful
2answers
2004 expedition third row seat will not go up. The fuses are good. Both motors would not have gone out at the same time. Do you know where any breakers or relays are?
By Guest on Jul 04, 2010
3answers
Third row seat in ford explorer stuck in down
my third seat is stuck in the down position . press switch to raise i hear the motor but nothing happens. 2006 ford explorer
Third-row bench stuck in down position
check for seat belt stuck in crack between seats back and cushion.
remove seat cusion to see if soemthing is stuck. see owner manual for directions. here's explorer
Rear Seat Backrest —Third Row Removal and Installation
  1. Release the two seat levers located at the lower outboard edges of the seat cushion. Lift out the seat cushion.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
