If your dishwasher top rack is not closing properly and is stopping when it reaches the spray connection, there are a few things you can try to fix the issue:
- Check the Spray Arm: Make sure the spray arm is not blocked by any dishes or debris. Clean it if necessary.
- Check the Spray Tower: Ensure the spray tower is properly seated in the dishwasher and not blocking the top rack from closing.
- Check the Rack Adjusters: Make sure the rack adjusters are properly positioned and adjusted to fit the dishes in the top rack.
- Check the Rack Rollers: Check that all the rollers are present, functioning and not damaged. If any of them are missing, damaged or not functioning, you should replace the rollers.
- Check the Track: Make sure the track the top rack rides on is clean and free of debris.
- Check the dishwasher's leveling: Make sure the dishwasher is level. If it's not level, it can cause the top rack to not close properly.
If the problem persists, it may be an issue with the dishwasher's design or a malfunctioning part that may require a professional to fix. It is best to contact the manufacturer or a qualified technician for further assistance.
It's important to note that the above steps is a general guide, and specific instructions may vary depending on the model of your dishwasher.
Hope this helps!
