If there is anything else that can be replaced that would stop it from surging,I would like to know what it could be after all that has been done. I am afraid to use it if the power goes out because I am fairly certain the power it generates can't be clean due to the surges. Can't be good for electrical appliances in the house.
SOURCE: POWER OUTAGE. now no power to computer
labefam,
sorry to say,but i agree,u rili killed ur computer..so the only thing u can do is to bring to a technician..coz there might sum parts of ur computer that were damaged..
SOURCE: Generator won't start & now starter will not shut off when it has power
I'm assuming the key ignition switch has been replaced with a new one. If this didn't correct the problem then the problem could be in the STARTER RELAY stuck in the 'on' position, or in the STARTER SOLENOID switch (located on the starter motor ) stuck in the 'on' position.
The STARTER RELAY should be located around or in a POWER DISTRIBUTION BOX . After locating the STARTER RELAY and gaining access to it, try hooking your charger or jumper cables, whatever way you want to power the battery to make the starter turn over, then while the motor is turning over then pull the STARTER RELAY out and see if that stops it from turning.
If it does then the STARTER RELAY is probably at fault and needs to be relaced. It the motor continues to turn over then the problem is more than likely the STARTER SOLENOID sticking in the 'on' position, and will need to be replaced. That should take care of the starter problem.
Next will be the 'not starting problem'. That could be fuel delivery, spark plugs, coil or ignition control unit. Would be so much more helpful to include date and make of an appliance when seeking help.
SOURCE: Coleman Powermate only puts out 110V
If you haven't seen it yet, here is a page that may help with a manual or parts list.
This problem sounds kind of bad, generators don't do well when the engine stops under load.
Start by checking the circuit breakers in the distribution box (outlet panel) - you need ot do this with an ohm meter. After that check the power windings of the stator with the ohm meter, be sure to check between the 2 windings (should be open), and from each one to ground with the winding isolated.
Whining, a burning varnish smell, and breakers that trip all the time are indicators of long term overload problems. This could happen if you had most of the load on one winding for a significant amount of time, or if the one winding mostly powered motor-like loads with high startup currents.
You may want to look at this answer I posted some time ago.
Regards,
Carl
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
