Motor runs, no parts move, machine will not sew.
SOURCE: i have a necchi model number 537fa. the light
If it is a belt problem, you should be able to hear the motor running. If you cant hear the motor running then it has to be the foot control or cord or possibly the motor.
SOURCE: My Necchi 537fa is sewing sluggish. Motor spins but needle moves slow. What do I do to fix this?
If your Necchi has an external motor, take the belt off and run it.... is the motor sluggish? If so... that's where you start. motors need to be oiled, typically with oil and grease ports on either end of the motor housing.
If the motor spins up nicely,... you need to clean and oil the rest of the machine. Start underneath if the bottom workings are exposed, oil all the places where metal joins metal. Then do the bobbin and feed dog area... then look along the top and sides for oil parts.. give them a drop or two...Finally, see if you can get into the head where the take up lever and such are... oil the needle bar, presser foot bar, etc.
It's a dirty job... so prepare a good space for your machine. Liquid Wrench will help you free up gunked up and rusty parts. Fine grade steel wool (0000) and Cotton swabs help.
Good luck
