THE BOTTOM THREAD WONT THREAD
SOURCE: SEWING MACHINE BROTHER LS 1217
if you put in search online .......brother ls 1217 threading diagram it will give you completeresults to print out
SOURCE: Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
SOURCE: my thread tension knob fell out of my machine and
My machine was doing the same thing its a sunstar 340-bl.Any way it was caused by aplying to much tension.To put back in remove barrel buy undoing grub srew,once removed, barrel will have one or two screws these are what hold tension shaft under tension in place.I can not advise on how much tension as i have different machine and once you destroy your spring thats it,you need a new one.To much tension causes it to untwist.
SOURCE: can't draw up the bobbin thread
Make sure you have enough of a "tail" from teh bobbin... Probably 4 inches or so before starting. If that doesn't work, check upper tension and needle is properly seated.
The needle drags the thread down and then starts back up causing a loop at the eye which a shuttle goes through and acrries the upper thread over the bobbin. The upper thread then drags the bobbing thread up.
SOURCE: I'm new to sewing. I was given a Brother LS-1217
Page 15 in this users guide.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1217_EN_186.PDF
