Question about Mitsubishi WS-55819 55" Rear Projection Television
Mitsubishi Rear Projection TV Model WS-55311
Picture blacks out with audio remaining in any channel. Picture may attempt to return after minutes or hours. Sometimes screen has horizontal flashing lines or a faded picture and will then turn to full color with quality resolution for a short time. It then returns to a black screen.
Rear projection TVs are dinosaurs. Sell it if you can get anybody to buy it and get an HDtv they're pretty cheap now not to mention thinner, lighter and better for your eyes. Imagine the space you'll save if you mount it on the wall and the cost of electricity. Not trying to be a jerk but it's time to move into the 21st century. The picture is waaaaay better.
Posted on Nov 13, 2014
SOURCE:
  • 1153 Answers
SOURCE: Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Posted on Sep 14, 2007
  • 179 Answers
SOURCE: Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Posted on Nov 28, 2007
  • 395 Answers
SOURCE: 60" Mitsubishi Problems
1. NO VIDEO, BUT HAS VIDEO WITH PIP ON. CHECK C763 (1UF 50V) ON THE BASE OF Q715, LOCATED ON THE UCOM-PCB. 2. NO MAIN VIDEO, THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB. THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PART # 181P504090. (CHECK ALL 'SMD' ELECTROLYTICS AND TRACES ON PIP) 3. NO MAIN OR PIP VIDEO, CHECK C7014, 47 UFD 16V ON THE PIP PCB. PART # 181P502060 4. CHECK FOR 7.2V DC ON THE BASE OF Q7003, IF LOW OR MISSING. CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PART # 103P401050 5. SUSPECT R2045/R2048 (6.8 OHM 3W) FOR OPEN/RAISED VALUE. LOCATED ON PCB-SIGNAL AT 5V REGULATOR IC2003 PIN 5.
Posted on Jan 21, 2008
  • 927 Answers
SOURCE: vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Posted on Jul 31, 2008
MNfisherman
  • 11896 Answers
SOURCE: green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
Posted on May 06, 2009
Broken screen on model WS-55311 MITSUBISHI
If its the outer protective screen that u need I have one. I didn't like the glare it provided me with so I took it off. Email me remarkable14u at yahoo dot com.
Dec 25, 2013 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55311 55 In. Rear Projection Television will power on but won't stay on
When it shuts down have you tried accessing the self diagnosis feature to retreve the error code?If so whats the blink code your getting?
Feb 10, 2013 | Mitsubishi WS-55311 55" Rear Projection...
How to unlock my keys on my mitsubishi tv model #ws-55311
Here is a link to the owner manual for this model--keyboard lock release is on page 32---might want to down load a copy of the manual as it is free.
http://www.scribd.com/doc/35942919/Mitsubishi-Owners-Guide-TV-vs-50111-Vs-60111-WT-42311-WS-48311-WS-55311
SD TECH
Jun 02, 2012 | Mitsubishi WS-55311 55" Rear Projection...
Model 55311 Can you pick up digital tv without converter box?
I am thinking that you have a Mitsubishi WS-55311. If this is the case, you will need a converter box to receive digital television signals.
I hope that this helps you resolve your issue.
Thanks for using Fixya
asnowman
Sep 20, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Picture black out
Like your computer a tv has the same type of circuits, & sometimes they get glitches, maybe, but i feel you might be starting to have a problem in the 'DMD" board in your tv. Maybe not; unplug tv for 10 min to 24 hrs. I am a mit factory auth tech. good luck,.
Jan 05, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WS-55311
check the error codes to see what's wrong, do this by search threads here or at ctechnicians.com
Dec 31, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WS-55311, 4 yrs old, flashing screen on all inputs
First thing to try is to press the reset button on the front of the TV. This forces a system reset.
Feb 03, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
