There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
2 SEGMENTS FLASHING RED - The console has overheated.
3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
E45 - Update Error.
E64, E65, E66 - DVD Drive Error.
E67, E68, E69, E79 -Hard Drive Error.
E71 - Update Error.
E72 - Unknown.
E73 - General Hardware Error.
E74 -AV cable error.
E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Possibility of mechanism fault inside the VCR, which might include tape damage. Can't answer directly about the 03 code, without knowing make or model number as they all use different fault codes.
Taking the top cover off might show up what's happened.
Red ERROR LED
The way the unit gives diagnostic codes is by long and short flashes of the specific light. The number of long flashes give the first of two numbers and the number of short flashes give the second. For instance, one long flash and three short flashes would indicate an error of 13 -
E 00
(No light, beep only) - MPU error
E 01
DRAM data line error
E 02
DRAM address line error
E 03
RTC chip error
E 04
Flash rom error
E 10
UPS power loss
E 11
fan error (RPM too low or not functional)
E 12
cooling error (unable to remove heat by the fan)
E 15
disk error
E 16
unable to locate internal HDD
E 17
Unable to communicate with the RTC chip
E 21
unable to communicate with the Phy chip
E 22
mount error.
The original Buffalo firmware has the following error messages based on the number of flashes:
Partition problem with hard drive. Reformat the hard drive.
Fan problem.
5
ROM problem.
6
Hard Drive can not be recognized.
7
Problem with motherboard (RAM, LAN, or Hard Drive controller).
Exerted from http://buffalo.nas-central.org/wiki/Information/LSProLED
I hope this has been helpful, unfortunately without more information I cannot help any further.
usually with 1 red light errors, there will also be an error that shows on the screen like e73, e74, e75, etc. You will need to first get your secondary error code.
then enter either the e-code from the screen or the secondary error code into the repair guide
E7
03
Scanner position error
04
Exposure lamp blown
05
CCD calibration error
12
White level calibration error
14
Main board malfunction
15
Exposure lamp blown
L1
00
L3
00
L4
01
Main motor drive overloaded
L6
10
Polygon mirror motor not up to speed
H2
00
Fusing unit temperature error
H3
00
Overheated fusing unit
H4
00
The fusing unit doesn't heat up
U2
01
Counter error
04
EPROM error
CH blinking
Dev unit is not properly installed
