SOURCE: Dishwasher (whirlpool quiet partner II)
I think I solved the door leaking problem by cleaning out the plastic filter screen on the inside (left) door panel. Didn't even know it was there, never knew it was suppose to be cleaned! It was so clogged and gross. I also discovered that my washer had shifted and was off balance. It has wood shims under the steel casing and one block was loose. No doubt from slamming and banging the door open and closed. Had to take the front skirt and kickplate off to see. I had my son use a lever and hoisted it up a little while I replaced the block shim now making the washer level again. Ran a light wash before fixing problems and it leaked. We ran a light wash after the fix's and so far so good. Haven't ran a regular longer wash yet. My water level was fine, no gasket problems, no washer wand cracks, etc... My husband was thrilled! When he came home, I informed him I have good news and not so good news. The not so good news was dinner was going to be late, the good news was I fixed the leaking (for months!)dishwasher and saved alot of money on repairs!
**Cleaned filter screen, made dishwasher level again.
SOURCE: RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
SOURCE: My whirlpool Quiet Partner 1 leaks from the bottom
Some leaking around-under-from the door on dishwashers can be traced back to a split in the spray arm. If the lower spray arm develops a split in it, the spray arm can turn too fast, and shoot water directly at things that it is not suppose to spray water at....sprays water at the door vents or edges and can create water leaks. See if thats the problem
SOURCE: whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
