Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
A
Anonymous Posted on Apr 06, 2014
Epson 4300 won't detect/charge genuine inks
Did one cleaning, got the first set of blue lines then no yellow or ppink or black. after that didn't even acknowledge there were ink cartridges in printer after cleaning then with rag
5 Related Answers
Anonymous
  • Posted on May 12, 2008
SOURCE: Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Anonymous
  • Posted on Oct 11, 2008
SOURCE: Canon IP5200 printer - "duplicate ink tanks"
Don't buy Canon. Canon allows this to continue, after selling you a faulty product, and does NOTHING to provide us with an answer or refund. The best way to prevent this from happening, short of any accountability from CANON, is to simply stop investing in their dishonesty. Don't buy Canon.
old marine
old marine
  • 2426 Answers
  • Posted on Oct 14, 2008
SOURCE: Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Anonymous
  • Posted on Jul 02, 2009
SOURCE: RECOGNITION OF GENUINE CANON INK CARTRIDGE
most probably has been damaged.
ink cartrigde is damaged due to followin causes--
1. over heating  of head due to bulk printing
2. mishandling the cartridge.
3. repeated refillings
try this if you want to use this cartrigde again, it may work
1.  clean the golden contact points with isopropyl alcohol of cartrigde as well as the cartridge holder
2. remove cartrigde and install again after some days
possibility of fault in printer is minimal,
Antony
  • 64 Answers
  • Posted on Aug 03, 2009
SOURCE: The MP620 printer has 2 black ink cartridges. The
With these types of printers they will use all 4 colors to make black unless you configure it other wise. The link below will take you to the printers support page. In the box that says "please enter your question" type "how to use only 1 black ink". it will give you top results, just click #1 and it click on your operating system. Follow the instructions given and that should take care of it. If you have any other questions feel free to ask.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=17406#SupportDetailAct
My epson stylus cx6000 has stopped printing black. I've cleaned the print head, changed the cartridge and it still won't print black. What else can I do?
Be sure you are using genuine epson ink. Epson printers are "smart" and will not allow generic ink to work properly. Even after you replace a generic with a genuine it may take several print outs and alignments to get it to print again.
Black ink won't print
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!! Don't print too much or else you'll use up all of your ink.
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
CX5200 STYLUS EPSON...THE YELLOW NOZZLE IS NOT WORKING aLL OTHER INK PRINTS EXCEPT THE YELLOW..HAVE TRIED DIFFERENT INK SOURCES AS WELL AS CLEANING HEADS SEVERAL TIMES ....
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
Unable to print with black ink even after several head cleans which uses loads of ink. Is there any way of just cleaning the black head???
1helpful
2answers
I JUST PUT IN NEW INK CARTRIDGES IN MY CX6000. THE BLUE ONLY SHOWED ON PAPER THEN ONLY YELLOW CAN YOU HELP ME PLEASE
This is the only advice I can give you. If you find this helpful, pls rate me.
2helpful
Hi, when printing the page is full black. After head clean, nozzle check etc still black & nozzle check prints two x dark lines. I changed ink cartridges but no improvement. Thanks, Roger
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
1helpful
After every line of black text there is a light blue line.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
2helpful
My epson stylus photo R240 skips black lines when printing even though I have clean the print heads 10 times .
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, skip lines, put stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
2helpful
When I do a nozzle check (I've cleaned the heads several times) there is no black ink in the printout and the blue ink is spotty.
Are you using Genunine Cartridges!!!!
I changed the black ink cartridge, and now it prints, but the paper is blank.
Epson Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
old marine
old marine
ZJ Limited
ZJ Limited
