Question about Jabra Extreme2 Bluetooth Headset
Distant and Tinny Audio
Sounds tinny, distant, fuzzy , clarity poor and sound quality poor. How to improve the quality of the calls Paired with a Pantec Mobile Handset and an Apple 4s
Tinny sound on tv
You might have a defective audio amp. One thing you can do is try to compare the impedances of the audio amp's left and right channel (tv off) outputs with speakers disconnected. any major inequality in (ohm) reading obviously will tell you so.
Dec 30, 2013 | Philips 52PFL7422D/37 TV
Motorola H19txt has very poor sound quality
sadly you have poor quality loudspeaker. the only thing u can do is plug in a powered speaker set into the headphone socket.
Nov 20, 2013 | Motorola Mobility H19txt Universal...
Tv poor sound quality
Check its speakers. If found OK, check and replace the audio output IC.
Aug 02, 2013 | Bush Televison & Video
2007 toyota camry audio poor quality
Yes, loose connectiosn, internal integrated amp device burned, bad ground or speakers go to bad.
Aug 22, 2012 | 2007 Toyota Camry
Sound quality is terrible on my Crosley CR79 turntable. Sounds very tinny and terrible. Got a new needle and the problem still exists.
This could be an earth lead to the cartridge problem, or the cartridge itself. Check the connections.
Feb 07, 2010 | Crosley 0187SST Turntable
Sound is terrible, except speakerphone
Hi!... You need to replace the ear speaker of your phone and it will be okay.
Oct 01, 2009 | Nokia 2600
Song sounds great on computer not on mp3 player
that's typical for this mp3 player - probably sounds tinny - nothing you can do about it
Aug 07, 2008 | Insignia Sport MP3 Player
Acer aspire 5633wlmi
How long has this been going on? Have you tried updating the soundcard drivers or rolling back to the last set of drivers if this is a recent problem?
Dec 30, 2007 | Acer Aspire 3680 Laptop
Mic troubles
Most shotgun mikes are only going to provide a mono output. In some cases there are two internal pick ups and the output would be stereo. A good example of this would be the Audio Technica AT822 which almost looks like two mikes joined together. I have a Sennheiser MKE300 and I modified the plug in order for the signal to be fed to both channels (double mono) I'm not familiar with your Sony mike and I would think that it would feed both channels, either as stereo or double mono, but perhaps it is not designed to do so. And being a hot shoe connection it wouldn't be possible to alter it until the editing stage. However, having said all that, the other problems you describe indicate a faulty mike. The low signal level indicates a lack of power to the mike, which in your case should be provided by the camera (unless there is a place for a battery in the mike, but I doubt it). I don't think it should be tinny either. I have had some issues with my Sennheiser picking up too much camera noise and handling noise but the audio of the subject is quite good. So, if you want a suggestion ... Take the Sony mike back - if you can. Buy a good quality shotgun (not the Sennheiser MKE300!) that has a standard plug on it (XLR or 3.5mm). Buy an external recording device (I use a minidisc and/or an Edirol R-1) This will give you greater control over mike placement and provide redundancy ( I recently recorded a wedding with a broken mike cable -I didn't find out until the editing stage that the camera hadn't recorded usable audio)
Sep 15, 2005 | Sony Handycam DCR-TRV19 Mini DV Digital...
Jabra Extreme2 Bluetooth Headset Logo
18 people viewed this question
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
