SOURCE: CHANGING THE RINGTONE
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STORE
SOURCE: change ringtone
With the handset on the hook press the conf button (the one with three phones on it).
The phone should ring with your current ringtone. Each press of the conf button will advance to the next tone.
pick up the handset and put it down again to select the ringtone.
I think there are 8 to choose from.
SOURCE: RING TONE VOLUME TO LOW
While the set is ringing use the volume arrows next to the handset to adjust the volume.
SOURCE: How can I change the ringtone on my Toshiba DKT3010SD?
the Above is incorrect... to change ringtone on a toshiba Strata DK series you will need to go to system programming and go to program 80 and choose from 1 of 3.. if its a CTX its in system programming and must be done from admin PC and many more to choose from.
SOURCE: How do I change the ringtone (incoming call) on
You can change the incomming ringing for your set by pressing feature *6 , press the next key to select the ring type and ok to store the new ring tone.
