Intex Easy Set Pool 15x36 Logo
j
jennifer Posted on Apr 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ring doesnt keep air - Intex Easy Set Pool 15x36
Mike Tellegen
Level 3:
  • Intex Master 1,631 Answers
  • Posted on May 18, 2014
Mike Tellegen
Intex Master
Level 3:
Answers
1631
Questions
Helped
1013009
Points
5840
Put some Ivory dish soap, about a tablespoon, in a quart bottle with a sprayer, and fill the ring with air.
Then start spraying the soap solution all over that ring. When you see "Bubbles" appearing, that is where the leak is. Patch it. Fill with air & repeat. If no more bubbles, you have fixed it.
Ihave 1991 k/q ,has blow by but doesnt smoke but keep running it will blow out oil alot have shut down,??
blow by is cause primarly from worn rings and worn bores. The fix is to bore out the cylinders and fit over size rings. The major reason for blow by is a faulty air filter system that allows the engine to be "dusted" in use.
Oct 22, 2014 • ATVs
1helpful
I used compressor 3 wks ago and worked great.Now will not compress air above 25 psi.changed regulator OK,removed air intake filter,it has suchion.removed outlet tube,bloweds air.Oil in site glass.I did...
Mike:
If you have air blowing out of the oil filler cap, I would suspect that the piston rings are shot. The piston rings are supposed to keep the compressed air above the piston, and air seems to be leaking past the piston rings into the crank case.
Stanley n60 trigger blow by
Sounds like o-rings. Have you tried replacing the o-rings?
Freon doesnt stay in. It keeps dripping out. Dealership quoted over $800. Is there a temp fix to this problem?
nope.depending where it dripping from.if its from a metal air con hose joint then its a $2 o ring seal and some re gassingif its from the compressor then it could also be leaking compressor oil, and if it has been running with no oil then it could be rooted mate.if its leaking from behind the dash then it could be a little tricky.
take it to a recommended auto mechanic with an air con license and he will ascertain the location of the leak.
$800 is what you would expect to pay to install air con to a car that hasn't got it already
Mercedes 250 td air in fuel lines
I had the same problem with 1999 E300 TD 6-cylinder in-line engine.
The problem was the o-ring on the pre-filter. Make sure all o-rings are tight and try putting small amount of silicone grease when installing them.
3helpful
2answers
My impact wrench wont engage to the socket.
I have the same problem, brand new impact wrench, brand new impact sockets, but can't get a socket onto the gun. Leaned on it with all my weight, wiggled, nothing. and yes they are both 1/2" drive. WTH?
3answers
Cant keep my RM 250 2 stroke running
DOES IT STOP RUNNING BECAUSE OF A FOULED PLUG WHAT RATIO FUEL/OIL ARE YOU RUNNING
40:1 IS A GOOD RATIO NEVER HAD A FAILURE IN 20 YEARS
2helpful
My hitachi nra 83 a2 doesnt fire ...when you plug it to the air hose ...air comes out of the top ... it doent fire
you need an o-ring repair kit. the part number will be located in your owner's manual. a blown upper o-ring is usually due to leaving it out in the weather for extended periods of time or hooking it up to a compressor with a psi regulator set over 120.
Ring length
HI go to ur mobile's setting > restore fectory setting > 12345 code > restart ur phone. call costmour care and deactivate ur voice call. i hope my idea is very greatfull to u. keep voteing.
Mar 15, 2008 • Cell Phones
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
