First off, I read the 6 pages of solutions. I have already changed my battery and the man said it looks good inside (brand new, which it is) After setting the time it takes about 3 weeks to suddenly be 2 min. behind. Doesn't sound like much, but shouldn't it be better than that? The original battery tested out good. I still had the new one put in. Comments? Suggestions?
SOURCE: Longines watch problem
Some longines watch has built-in battery gauge. When battery is low, the second hand jumps every four seconds. If you have new battery installed and the problem persists then there is a short circuit somewhere that drinks a lot of battery juice.
SOURCE: Watch stops sometimes and then restarts
If it's new, then just take it back to where you got it. There is no way your warranty can run out in a week.
SOURCE: casio watch problem
Appreciate the direct "Ask Me".
Offhand, I would say yes to the battery replacement. Though watches are not within my immediate field. This would be based on your post "2-5 minutes behind". As to the "lost signal" after a reset, may I request that you post back the specific model number pls.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
SOURCE: my ebel watch loses time
get them to have it checked in their repair shop and tell them its not the battery
SOURCE: Swatch Skin #SFK254 ,Time always late
Simply pry the battery cap off and remove the battery for at least 24 hrs. to depolarize the watch.And then reinsert battery and snap cover on.Your skin is back in order.Good luck.
