It shouldn't agitate on rinse cycle. ''Quick wash'' is the last type of ''cycle'' you can select that the machine will ''agitate.'' On ''rinse'' cycle, it will fill with water and then simply drain & spin.
The draining problem could be something stuck in the pump. A easy fix just take it apart and get whatever is in it out of there. The agitator sits atop an agitator drive block. The spline on these tends to strip out. Yank off the agitator (it just snaps on) and replace the drive block.
The typical cycle is; fills to selected water level agitates wash cycle drains wash water spins wash cycle fills to selected water level on rinse cycle agitates on rinse cycle drains rinse water spins final time end of cycle
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
