SOURCE: when you pedal the front sprocket and chain turn
On the second gear from the front There should be a bolt that screws into the flange where the shaft goes through to secure it to the shaft. When this is tightened down it stops the gear from rotating on the shaft when you are pedalling. It is on the gear where the front chain provides power to the back chain. If the bolt is missing, you should be able to replace it with any bolt that is the same diameter and thread size as the hole in the flange. When I was still building these the bolt usually had a square head on it. Unfortunately I don't remember what size the bolt was. I hope this helps.
SOURCE: hello the center hub/freewheel keeps spining it
The hub needs serviced....normally one-way bearing isn't gripping in forward drive direction....recommend having serviced by dealer.
SOURCE: Rear wheel loses the connection with pedal and
http://www.youtube.com/watch?v=8AsV0ojyUMU&feature=PlayList&p=E8D0D1764E9A6D0E&playnext_from=PL&playnext=1&index=37
http://www.youtube.com/watch?v=Ptx0XInC4rA
http://www.youtube.com/watch?v=jZp-9xQfzJo
try this links... it ll help u
SOURCE: When I ride up a
Before you go tearing everything apart it might help to understand how multi-speed derailleur shifting systems work.
Derailleur Adjustment: (likely cause of your problem)
http://sheldonbrown.com/derailer-adjustment.html
Shifting:
http://www.sheldonbrown.com/gears.html
Cassettes and Freehubs:
http://sheldonbrown.com/k7.html
Chains: (which also covers worn gear teeth, another possible cause)
http://sheldonbrown.com/chains.html
Of course everything requires special tools and procedures.
http://www.parktool.com/blog/repair-help
http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Have fun.
SOURCE: My son's Schwinn Ranger is
ok well its best decided how to fix it if you can tell me what style of rim and freewheel you have if the freewheel goes all the way to the tip of the axle then its more than likely a cassette style rim and if it appears hollow at the axle end and you can somewhat see inside the freewheel then i would just buy a freewheel cassette for it because in most cases a faulty freewhell body cant be serviced and need replaced when they fail up on you another cause of this is riding in the winter so find out what kind it is and message me back ok ill better inform you of the best possible way to ride happier longer :) this is also a super common problem ok
