Here is a link to download another instruction manual
http://www.manualslib.com/manual/643579/Krups-Superiore.html#product-894
SOURCE: Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
SOURCE: Krups Espresseria Automic XP7200 coffee machine
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
SOURCE: My xp7240 has also started leaking water from beneath the machine
It seems like a piston sealig is damaged. Not so easy to replace but possible.
SOURCE: I dont have an instruction manual for a Krups coffee machine.
click on this link directly for user manual of Krupp 867 and yours is 866 but its the same.Download the complete
user guide (411 Ko)
This will help. Thanks please keep
updated.please please do rate the solution positively .thank you for using fixya
SOURCE: Dear Sir!
Check on the Krups site:
http://www.krups.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm
