Red lock light after being cleaned burners will not turn on and oven does not work
Good Morning Anonymous, thank you for your post!
Based on the symptoms you are describing, it appears that your Frigidaire range is possibly locked. Typically, the "Door Locked" light will glow until the Self-Clean cycle has completed or the oven temperature has cooled. However, if the issue continues, please confirm that the Oven Control Lockout feature was not accidently selected (on some models). If so, you can cancel this feature by pressing CLEAR/OFF and hold for approximately 10 seconds. The control will unlock the oven door and resume normal operations.
If the instructions above do not solve the problem, may I please have your model number? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can determine if your range is possibly experiencing other issues. Thank you - Z.
SOURCE: "door lock" light stays on and oven won't work
Same problems. When I removed the lock operating arm nothing happened. Motor is not operating. I've temporarily kluged it by tying the "unlock" (upper) switch circuit together and disconnecting one side of the power to the "locked" (lower) switch. At least we'll have an oven to use, but I'll have to come back and remove the lock motor assembly to find out what's really wrong.
BTW, if some knows those keyed-in service codes they could be useful.
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
SOURCE: cannot unlock oven frigidaire electrolux gallery series
Hello, what to do is to start another self clean cycle let the unit clean for about 3 minutes then push the cancel button.This should unlock the door if not a tech will have to come to advance the lock motor . good luck
hello. this is a common problem. here is a link to provide you with an owner manual which explains how to use the self-clean function
http://www.frigidaire.com/manuals.aspx
and here is a link to speak directly to the folks at frigidaire who will talk you through the solution to your problem
http://www.frigidaire.com/contactus.aspx
let me know how u make out with this as I can offer additional help if needed.
SOURCE: MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE
I cleaned my oven and now the door won,t open. The lock light is flaching.
