SOURCE: Only printing black and cyan
If you have used third party carts before you can't repair this problem due to the fact that the filter inside the printhead is clogged with particles. There is no chance to clean the filter. Sorry. Do use only dye ink. Pigmented ink is the printhead killer for brother printers!
SOURCE: Brother Printer Cannot Print in Black
This could be because of several probs: 1. The ink cart is not original and wont let the ink flow, because the valve is not open. 2. There might be air bubbles within the capillaries. 3. The ink is not genuine ink and has pigments in it. Solution: see here, too: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=dcp110c_us Insert another ink cart. Use, if possible, the genuine ink cart from brother. Do the cleaning cycle twice. This will extract the air bubbles out of the caps after the second time. If you dont have any success the printhead is clogged and cant be cleaned anymore!
SOURCE: Brother DCP 130C not printing magenta and yellow
after replacing the ink cartridges it took several cleans to come good. I have no idea how to "manually" clean the heads. So I told the printer to do it many (about 7) times. It eventually worked
SOURCE: Brother Intellifax 1820c fax machine: Won't print incoming transmissions
How do you fix the error 41 that keeps showing up
SOURCE: Brother Intellifax 1840C
the only one thing you can to do is stick masking tape around the cartridge, there is an switch, when you take off the cartidge the switch is off, when you put it on the switch is on, this is out = "off" and in= "on", do the same with the other colors.
greetings.
