It part that holds the needle has jammed and wont move back or forth. How can I fix this?
SOURCE: How do I fix a
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
SOURCE: repair singer 502 sewing machine
You can get the fears quite easily and fit them yourself and if you email me I can attach full instructions.
[email protected]
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
