I recorded and edited everything on my video. The problem is when i can't put words on my video straight from my phone. If i have to upload the video to youtube and then edit it again i'm going to be a little mad. What is your solution to putting words on the video from the phone? I also want to put annotations and i can't do that either. Please help!!
SOURCE: Need help uploading my k800i sony ericsson software
So is it your printer you don't have the drive for or your Phone? The most common problem is that you dont have the USB Flash files. Un-Install all drivers to do with your from from the device manager with your phone plugged in or it wont see the files. Then unplug your phone and restart your machine. When restarted leave the phone unplugged and use the SE disk to install the suite. When the suite is installed plug your phone in and the suite will load all the other drivers. If you dont have the disk, then download the PC suite from SE.
SOURCE: YouTube Problem Uploading
Did you try the YouTube Uploader? you'll first need to install it on a Windows computer. To do so, follow the steps below:
Once you've installed the Uploader, you'll be redirected to the Multi-Video Upload page.
SOURCE: Sony camcorder copy tape to pc problem
Hi, You need to connect to PC using a 4 pin firewire cable. and then switch on the cam. Import the video using Windows Movie Maker.
SOURCE: Rokr E8 uploaded video playing
check google for 'any video converter' its a brilliant yet straight-forward user friendly program which will convert from anything to anything. It's great and it works - i use it all the time and better yet... its FREEWARE :)
SOURCE: nokiA 5310
Hi
Most probably it is because of the music file format check the entire steps out
Also check the music file format
The Nokia 5310 plays MP3, WMA (windows format), AAC and M4A (also known as eAAC+), but only the non-protected files.
There is one way to convert your protected songs, which is to burn them to an audio CD (which is usually a "permitted" action for protected songs), and then rip them back to MP3 or so.
And please do rate me
To upload video to Facebook hover of the application and scroll down to video.
Click upload at the top right, and then select the file you want to upload.
There are limits to what you can size the file can be make sure you check Facebook's video policy before you upload.
Then give the video a title a description and select who can and cannot view the video.
You can tag the video to show who is in it, by typing in the name of the person in the In this video box.
If you have a webcam you can record your video right onto Facebook.
From the video main screen click record. You then have to give Facebook access to your webcam. From there you will be able to record as you normally would.
If you have video on your mobile phone and want to set it up so that you can upload video directly to Facebook, send an e-mail from your phone with the word video to [email protected]
They will send back a confirmation code that you need to enter on the website. Once you've confirmed you'll be able to upload video directly onto Facebook.
hope this helps
