How do I make the phone have fewer rings on an incoming call before it goes to voicemail? It's a Panasonic KX-T7633 model. On an advice given by an expert, it said to press *713 and then a 2 digit number between 00-99, but it doesn't work.
Does your system use the FWD/DND option or is it the programming. I also need to know what kida system this is.
If it is for the TDA then you can (if you have access too)
Prog soft key below LCD ->
the press FWD/DND button ->
Down on the silver button about 3 times. Should see 53:FWD N/A Time then enter
Should see timer (sec) :xxx with your current time.
Press new time example 015 for 15 sec then press enter.
If that doesnt work let me know and I get you the other way.
