Nintendo Wii Fit - Balance Board + Game Console Logo
A
Anonymous Posted on Apr 05, 2014
Communications with the Wii remote
While using the nunchuck during Wii Fitness Plus, I receive the error that communications with the Wii remote have been interrupted. When I press A to reconnect to the remote, I am only able to play for a short time before I receive the same error.
5 Related Answers
Anonymous
  • 125 Answers
  • Posted on Sep 02, 2008
SOURCE: Wii remote cursor not working in Wii Menu
I find it very irratating to navigate the wii menu as well. It seems our problem is the remote is very very sensitive to the sensor bar. You have to swing the remote around a bit to find the 'hand' you use to click on where you want to go. also, I find that I first have to press A when the menu comes, then almost have the remote 3 inches from the sensor bar. I have also tried putting the sensor bar in different loactions. Like, if we are playing standing up, we put the bar atop of the tv, otherwise if it is a game we can play while sitting, we put the sensor bar under the tv, on the stand (this is a 20") Try moving yours around and find out what works best for you. But it is frustrating as I too find that the remote is too dag 'on sensitive!! Even though I know it's fussy, we still have the problem daily, doen't get any easier! I hope this suggestion helps.
Anonymous
  • 67 Answers
  • Posted on Mar 13, 2009
SOURCE: nunchuck wii problem
Most likely not a fault with either. Try not touching the nunchuk while the game is powering up, as moving the joystick while the game is powering up can cause these issues. If the problem is still happening, click the Wii Home button and open the Wii Remote Settings at the bottom of the screen. Choose the option to reconnect the remote, and then try again. If this doesn't work, ai am not really sure what is the issue. You may need to send to NOA for a checkup.
Anonymous
  • 19 Answers
  • Posted on May 18, 2009
SOURCE: my wireless nunchuck wont sync with my remote whats wrong
Return the product and use the Nintendo wired nunchuck. The nintendo wired product is only 19.99 and the cord is not that bad of a deal.
Anonymous
  • 149 Answers
  • Posted on May 28, 2009
SOURCE: Nunchuck is not working even though connected to wii remote
The sensor may be gone.  The best way to test this is really easy and pretty cool to do.  Take two candles light them and then place them a little further apart than the wii sensor is.  If you are able to use the remotes then the sensor bar needs to be replaced and if ther is still nothing I would try replacing the controller because the infered led's may have gone out.  If that still does not work then the sensor decriptor in the wii has gone out.  Nintendo should be able to help you with that part.  But I do not think that it is the Wii.  I feel that your sensor bar is bad.
Anonymous
  • Posted on Jul 31, 2009
SOURCE: Wii not working
when putting in a cd its saying cant read disk
When using my Wii nunchuck, it is less responsive when I push left (For instance, in Skyward sword, Link will run when the joystick is pushed hard right, but will barely move when pushed hard left) I
Sounds like a possible nunchuck error (Yes, it can happen on both at the same time :P ) Or, I would recommend completely reconnecting the controllers and nunchucks to the sytem. You can do this by going to the home menu, disconnecting the controllers, and then holding both the red button on the Wii system (Under a little flap) and the red button underneath the battery pack as well (There is a small hole where a pin or needle can go in to).
Epic Mickey 2 wii on wii u remote and nunchuck problems.
Do you think it's the battery? Or maybe the back. If the wii loses power, either the game you are in will immediately pause or it will continue moving in the same direction you pointed it in before the wii lost power
Charge the battery fully, and ensure the nunchuck is clean.
2answers
Remove unsupported wii remote extension controller
This is an error that is reported when u have an extension/attachment plugged into your wiimote.. this can be either a motion plus, a nunchuck, anything other than just the wiimote itself is a possible candidate for this issue...remove it and the error should go bye-bye.. bye-bye :)
How do I sync the motion plus to the Wii remote?
There is no sync required. The motion plus connects directly to the Wii remote (where the nunchuck usually connects) and works through the Wii remote.
My wireless wii nunchuck doesnt work i plug in thr adapter to wii remote and turn it on it just flashes blue
There should be a sync button on the nunchuck or adapter press it. Then press the sync button(small red button)on the front of the wii console which is located behind the SD card access door. This should sync the nunchuck to the wii.
1helpful
We have bought a Wii Family Ski on ebay but unfortunately it does not have instructions. Can anybody let us have some instructions?
shake your wii remote and nunchuck when you get wobbley and shake your wii remote and nunchuck like a trians wheels to go and stop shaking the wii remote and nunchuck to stop
2answers
Wii remote
If you move your wii romote or nunchuck while it is loading, the control that was moved during the end of the load will move the character in that direction uncontrolled the whole game.
2helpful
7answers
How to drift on mario kart wii with the nunchuck/remote combo?
It says how to do it in the instruction pack with the game. I would tell you now but I can't recall how to do it
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
