Eos utility camera not recognized
SOURCE: EOS Utility program cant download pictures.
1'st thing. You don't have an EOS camera so you won't be able to use EOS utility.
SOURCE: EOS Utility does not Recoganize Camera
I am not sure about this matter but it seems there is a problem with your new computer. it might not recognize the usb cable.
try to plug your camera in another USB port and try again.
SOURCE: EOS Utility does not recoganize Canon Rebel Xti
I believe there are 2 modes of usb transfer that you can pick in the camera. They are set somewhere in the menu in the options. If you go through the menus thoroughly you'll find it. One option is for connecting the camera directly to a printer and the other is for computer transfer (there might also be an Auto setting but I don't remember for sure). Make sure that setting is set for computer transfer. If that doesn't fix your problem, re-install or update EOS Utility / ZoomBrowser.
SOURCE: My XT will not connect to Vista.
Well, that worked perfectly. Turn on your Rebel XT camera and under Menu then Tools go to Communication and set it to Print/PTP. Thank you to all you very smart people!
It's very hard to troubleshoot software problems online, and it likely is a software issue. You may fix it, but it will pop up again some day. Camera/cable interface problems are notorious. But why put up with the headache of these software problems? Please see the following post, as it outlines a much easier, faster, and less error prone alternative way to download your photos:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
