Red light flashes on prewash halfway through wash
SOURCE: prewash always flashing
yes i had a similar problem the prewash light kept coming on mid wash cycle and eventually stopped taking in the water just bypassing it straight to outlet without filling machine. i found if you remove the pump at the rear of machine and disconnect hoses there was a build of lets say deposits leading to a sensor through a opaque plastic connector to the top of machine . after cleaning the hoses thoroughly and removing all the crud machine worked as it should do, hope this helps
SOURCE: Washing machine Prewash light flashing.
hi on the model before this one the wma series the flashy pre wash light is a faulty water inlet valve these mashines are allmost identical inside so check that,first check that you have the hot/cold pipes on the right way around hope this helps
SOURCE: prewash light on machine will not go into next mode wash ?
Check pump and filter for blockage.
SOURCE: why Prewash light is flashing?
I think you need to clean pump filter, if not at front, then remove lower rear panel of washer, locate and remove large black hose on drum ,remove and clean filter inside, remove hose onto pump and check for obstruction there as well.
Please rate my solution.
Thanks.
