It does not recognize an 8gb sd card in storage expansion.
Your netbook should read SDHC(over 2 GB capacity) memory cards. The problem might be either the card slot driver, Which you should download if a newer one is available. Or in case you format the SD as DOS then it will only have around 2GB of space, You should format it as DOS32 or NTFS so you get the full capacity for the SD card. Some pirated rather cheaper memory cards have a lower actual capacity. With some compression technique the capacity presented is higher than it actually is. If you format it then it will show the real capacity. hope that is not the case!
Good Luck!
