Motorola Mobility HK250 Universal Bluetooth Headset Logo
A
Anonymous Posted on Apr 05, 2014
HK250 headset Whould like users manuel
Can't make calls
Voice Commands are dependent on your connected phone and how you press the button. HK250 Settings
Mark
Motorola Support
BT doesnt not repond to my replies
We recommend you contact Motorola Support.
CONTACT US
Mark
Motorola Support
Brand new HK250 bluetooth, been plugged in since 12:30 & it's still not charged. How long does it take to charge up?
no , bluetooth headsets are usually simple to pair , read your manual on how to pair with your device
Mettre mon motorola hk250 en francais
Hello
I have a Motorola HK250, I find several languages except French, ars there a way to add French as an option? thank you
My Motorola HK250 wont charge is flashing red all the time
Mine is too. Mine will sit solid red for a little then turn solid blue. Then after that it will flash red all the time. I've had it on the charger for the last 2 days and that's all its been doing. I read the flashing red light means the battery is either unchangeable or not making proper contact.
20helpful
How do I change language with motorola hk250 headset from italian to english
Turn off the headset. Then hold down the call button and turn the headset on again. The voice interface will ask if you want to continue in a number of different languages. When they ask if you want to continue in the language you want, press the call button again to select that language.
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
