Palm Tungsten T3 Handheld Logo
A
Anonymous Posted on Apr 05, 2014
Palm Tungsten C frozen. Did soft resets, still frozen. Finally a hard reset & freezes on the stylus tap page. HELP!
5 Related Answers
otacon
Damen Wong
  • 1950 Answers
  • Posted on Jan 19, 2008
SOURCE: Palm tungsten E2
Does anything happen when you try to turn it on? Does anything respond or light up?
Anonymous
  • Posted on May 14, 2008
SOURCE: palm treo screen freeze
Get a Blackberry and forget this inferior technology. That's what i did and i have never looked back!
Anonymous
  • Posted on Jan 15, 2009
SOURCE: Touchscreen and/or stylus are not working
place in your palm and give it a good sqeez workes
Anonymous
  • 164 Answers
  • Posted on Jul 25, 2009
SOURCE: Palm Zire 71
The top plastic digitizer is defective.
It needs to be replaced.
There are several sources on-line to buy such digitizer part.
Best regards,
Anonymous
  • 164 Answers
SOURCE: Palm Tungsten E2 stuck on Tap the center of the target
The digitizer part is defective and needs to be replaced.
You can find digitizer parts in ebay or other on-line companies, at reasonable prices.
Regarding the labor cost, depending of the repair shop you choose, it may be cheap or expensive.
Also, if you have minimum experience and skills in fixing electronics, you can try it. really is not so difficult, and minimum set of tools are needed for it
Best regards,
3answers
Palm T3 frozen, tried restart in hole, nothing?
Doing a soft reset A soft reset tells your handheld to stop what it's doing and start over again. None of your information will be lost. After a soft reset, a screen appears that lets you reset the date and time, if needed. To do a soft reset, use the tip of an unfolded paper clip (or similar object without a sharp tip) to gently press the reset button inside the hole on the back panel of your handheld.
If a soft reset does not unfreeze your handheld, you need to do a hard reset. Doing a hard reset Only do a hard reset if a soft reset doesn't solve your problem, or if you want to clear all of your information from your handheld. [!] IMPORTANT A hard reset deletes all records and entries stored on your handheld, including the username that identifies the handheld. Before you do a hard reset, be sure to synchronize.
1spacer.gif Press and hold the power button. spacer.gif 2spacer.gif While holding the power button, use the tip of an unfolded paper clip (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld. spacer.gif 3spacer.gif Wait for the Palm Powered™ logo to appear, then release the power button. spacer.gif 4spacer.gif When you see the message that warns you about erasing all of the info on your handheld, do one of the following: blank.gifPress Up on the navigator to finish the reset and show the Digitizer screen.
blank.gifPress any other button to do a soft reset.
Frozen Blank Screen - soft reset doesn't work.... Do NOT want to do hard reset because all my data will be lost and it is my life line. I am panicking. Please help!
If you back up all your data on your desktop it will be restored with your next hotsync after the hard reset. I recommend the hard reset but if you really don't want to try that they I suggest you try using the free palm chat. Here is the link for that. Be sure to scroll to the bottom of the page and you will see palm Chat. Click on the link that says chat now and follow the prompts. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/e2/unlocked/supportservices/page_en.html
My palm e2 screen brings a frozen screen even after reset and no button whatsoever works, it can reset but freezes on the screen again,that is 0 alerts. even the power button does not work, only reset,...
You can try doing a hard reset. A hard reset will delete everything on your device. All your data will be deleted, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything. Here is the link for directions for the Hard Reset:
http://kb.palm.com/wps/portal/kb/na/tungsten/e2/unlocked/solutions/article/42094_en.html#tx
My palm tungsten e2 has been frozen for 45 minutes
do a soft reset, press the reset button on the back of the unit, if you still have the stock stylus, the top will unscrew to expose a reset pin, to allow you to access button. Press the button, screen should sow a restart, then your starting point.
Hope this helps
Ed
3helpful
2answers
How to resart?
Go to this url and select what you want to do for detailed instructions. Save the url for future reference...Enjoy and please rate this solution.....
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=5183,E=0000000000342449107,K=3005,Sxi=8,Case=obj(887)
Sudden appearance of "alerte fatale" (french)
you will have to do a soft reset. Google on the web how to soft reset the palm tungsten e. It is just slightly complicated. If that does not work you may have to do a hard reset which you can also find out how to do on google but i dont think you will need to
Palm Zire 71
Best regards,
1helpful
Urgent response needed
1 press and hold the power button
2 while holding the power button, use the stylus to press the rest button on the back
3 wait for the "palm powered" logo to appear and then release the power button
4 when you see the warning message
either press "UP" on the 5 way navigator to reset
or
press any other button to do a soft reset
Best of luck
Palm is locked up
I would say if you have all of your information saved to the profile in Palm Desktop to do a Hard Reset.
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
