Good Afternoon Carolyn, this is Z. I am happy to assist you!
I see that you are receiving an error code E93 on your Electrolux dryer. Typically this indicates that the main control board has possibly gone bad or is not communicating correctly. I would suggest resetting power to your dryer for roughly ten minutes. If the error code still displays, at this point, I strongly recommend connecting with a local appliance tech that has the expertise to distinguish which part is the culprit. I hope this information proves useful.
From what you have described your Electrolux dryer is displaying an error code of "E75". An"E75" error code is not showing as a valid error code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your dryer. You can do that by disconnecting the power from it for ten minutes. Could you please provide me with your model number? You can normally locate the model number on the serial tag which is located on the door frame. Also, once you reset it can you provide feedback if you continue to receive that error code. Good luck. -Matt
E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
After that the display will show one of the following errors that are more precise:
E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
E94 - Incorrect configuration of washing cycle.
E95 - Communication error between microprocessor and
EEPROM. Posible causes: Electronic board faulty.
E97 - Incongruence between programme selector and
cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
Hi - Typically error code E08 on Electrolux models indicates that it is recommended for a professional to check the mist value on the motor. Try resetting the unit by unplugging it or flipping the breaker to the household circuit breaker. Wait approximately ten minutes and turn on the dryer. If the error code does not clear and it is ineffective, contact a professional to move forward accurately.
Dryer had been overheated (clogged or damaged air filter). Reset 3 thermo-fuses (small red buttons): 2 under top cover and 1 under back side round cover
