I am paired to bluetooth and able to hear phone calls on Jabra
SOURCE: Jabra BT135
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
SOURCE: Jabra bT260s Pairing problem...
You may need to change your output sound device. The method may vary depending on your software and hardware, but go to Start -> Control Panel -> Sound (I think. Doing this from memory, so might be slightly off). There should be a Devices or Output tab. Change that to your bluetooth headset. You will probably need to restart WMP before you hear music, too.
SOURCE: Need to pair jabra Bluetooth car kit with mobile
You need to put the Car Kit in pairing mode, usually done by starting with the power off and holding the power button till the light flashed Red and Blue or solid Blue.
Then search for the car kit from your phone. Once found pair using pin code (pass key) 0000 or 1111 or 1234.
SOURCE: GNM-OTE3 Jabra Bluetooth Headset is blinking 3
Have you already tried to put your headset in pairing mode first? Anyway, to do it, starting with it turned off, press and hold the on/off button for some 5 seconds, until the indicator light is steadily lit (it will flash as it was being turned on, but don't release the button at that phase). Then, make your phone'sbluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros);
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
