Every time I plug the headset in a blue light flashes but seems not to be charging, and when i unplug it it wont turn on when i press the button, and won't connect to bluetooth
SOURCE: Iam looking for replacement earbuds for my
I did exactly what geozep0 indicated in his comment with similar successful results. I called the Motorola customer service number: 1-866-289-6686. Per the representative I spoke with, Motorola's standard warranty policy covers the entire unit (including the earbuds) for one year from the date of purchase.
They are sending me new earbuds free of charge.
Success!
SOURCE: Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
SOURCE: Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
SOURCE: motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
SOURCE: regarding my motorola Rokr S9,,,,,,my light is
how to charge and switch on Motorola S9-HD wireless headphones...please help me
