There will be a conversion kit for center console operation for the gauges so talk with the dealer spares for advice
If the unit is still under warranty
have them do the job to preserve the warranty as any work done you ( properly done or otherwise ) constitutes an unauthorized work and that could void the warranty
SOURCE: Dacor Cooktop gas conversion
Check this link for the steps:
http://www.skymarkinternational.com/images/resources/38.pdf
Hope that helps.......
SOURCE: TOYOTA fuel and temperature gauge
Some cars have a second fuse box under the hood near the battery. See if your car doesn't have one of those.
SOURCE: 2003 F350 Intrument Cluster
If everything keeps going like that then it sounds like its a problem with the onboard computer. The computer controls all the guages and would explain why they all fail at the same time.
SOURCE: gas gauge, temperature gauge don't work; TC light won't turn off;
there is usually a button on bottom of the steering column to push to take the key out of the ignition. it should allow you to turn the key to the lock position
SOURCE: speedo for a 80hp yamaha outboard
The sender is a plastic flip up fitting located at the bottom of the transom. They have two positions. Down and in the steam below the bottom of the water for reading the speed. Up to protect when trailering. Check to see if it is up. I never heard of a unit that is attached to the engine itself.
