Looking for a part but not listed on diagrams. The part is located in elbow shape section on the bottom end (close to the cutting string). If you take apart the elbow section it will expose upper and lower gear type items. My upper gear is stripped and I need to replace it but I don't know the part number. Appreciate all the help. Thank you, Ken
SOURCE: can't figure out how to put on new string after i took off the old string
I figured it out. Went on YouTube and watched a couple videos and did it myself. Thanks!
SOURCE: Craftsman 917273223 50' cut. Hit a stump with
you need to bring all 3 blades to point at each other on the deck
do they all look the same?
aLL 3 should meet each other evenly with no more than 1/8th inch difference high or low point to point.
the stump strike could have bent the deck on that side
also be sure the fin side of the blades are pointing towards the deck when installed.
check that your deck is level on a level surface and the air pressure in all for tires are up to recommended pressure.
most of the time 14psi front and 10psi rear
SOURCE: WHERE THE TWO GEARS COME TOGETHER AT THE END OF
I recommend replacing the entire trimmer with a new one, even if you can get parts it's not cost effective unless the machine is within warranty.
SOURCE: Sears 12" bandsaw Model 11324200 I
Here is a link to the parts diagrams. You can order new parts and have them shipped right to your home.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113247210/0247/0744100?pathTaken=
