Canon IR 2020 showing system Error E007 printer willnot print
Your problem possibly is a damaged fixing film,check the counter ,if it´s over 150k the side of the fixing film over the movement sensor is damaged.exchange needed
All copies at a time recovery how ? in the machine canon ir 2020i
Friend, check the printer cable if properly connected because such message is the effect of cable malfunctioning. or try to re install your printer driver to be sure that the software is good.
Hi I have problem with my canon Ir 2020 after 3 or 4 copy it shows Error E007 .. and some times when i turn on the copier it shows this error .
it is a problem of fixer fuser unit, change it or check a fixer sensor
