Question about Briggs & Stratton Garden
Cox ride on mower manual
How to put drive chain back on a cox 13-32
    Top Expert:
  • Briggs & Str... Master
  • 5,306 Answers
Check this site.
https://www.manualslib.com/
Posted on Apr 03, 2019
SOURCE:
wadembly
  • 513 Answers
SOURCE: i need a repair manual for a scotts riding mower.drives a few fee
it could be the axel they have spider gears in them & the teath could be sheared or the the rearend is low on fluid
Posted on Jun 05, 2009
bargainbin2
  • 123 Answers
SOURCE: need a diagram on how to put a drive belt back on
It is a hard one to put on co look at the picture carefully there are two pulleys one that one side of the deck that are trickey.
Posted on Sep 01, 2009
  • 582 Answers
SOURCE: ride on mower not starting, battery fully charged,
TAKE A PIECE OF HEAVEY WIRE AND RUN IT FROM THE POSITIVE POST ON THE BATTERY AND TOUCH IT TO THE STARTER POST SEE IF THE STARTER WORKS. IF IT DOES CHECK ALL THE SAFETY SWITCHES ON THE SEAT, DECK , BREAK ECT SEE IF THIS HELPS
Posted on Sep 06, 2009
Testimonial: "Thank you i now know what the faulty part is, excellent tip."
SOURCE: chain came off r70 riding mower how do i put it
ok there is three sprockets one on the transmission a guide in the middle and onle on your back axle. take a wrench and loosen up the middle sprocket. slide it all the way back untill the chain is snug or tight. tighten up your bolt and it should notice it drives faster and thats how you keep it from falling off. hope it works for you
Posted on Jul 02, 2010
  • 16 Answers
SOURCE: I have a victa corvette cox made ride on mower
Being cox made I'd go looking for cox manuals for the same era. Victa just rebadged others mowers.
Posted on Jan 29, 2011
I need a manual for a Cox Scout XL 28 ride on mower.
Google (cox)(20L7)(manual) without parens.
Jun 30, 2018 | Garden
Do i need to replace fuel tank if rubber grommet has come out
cant find a picture of a cox ride on mower fuel tank
should be able to buy a grommet to do the job
mower repair shop first stop
Nov 05, 2016 | Garden
How to put belts in cox ride on 5303l model?
Set the mower on its side prop it so it can't fall loosen the adjuster s remove old belts and fit new ones (the back axle belt could have slotted mount bolts as the adjustment.
Nov 03, 2014 | Cub Cadet LTX1040 Deck Belt 2009 Only...
Why would my cox lawn boss stop driving forward and back when I engage the mower deck
Sounds like a drive lockout switch. Check under seat or dash. EBrake? Good Luck
Oct 18, 2014 | Garden
How to change blades on a cox stockman mower
You will have to put it on ramps or find some way to get it off teh ground so you can get under the deck. The blades will have 1 large nut that you need to remove and thats it. Just take the nut off replace the blade and put the nut back on.
Mar 04, 2013 | Garden
Looking to buy Drive Cone for Deckson ride on mower
Can't help you with the source, but I also want one.
The old part on my machine has a one inch hole (25.4mm) and I suspect yours has this also as back then B&S engines sported a one inch shaft. I'm thinking that I might have to get one machined, but finding that thick fibre material to start with will be a problem also.
Dec 13, 2012 | Garden
Nov 18, 2009 | Garden
Garden Logo
232 people viewed this question
Top Briggs & Stratton Garden Experts
John Trevino
wadingriver
wadingriver
JOHN LAPIER
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
