Question about Jet Tech Systems F-22 - Dishwasher, Door Type, high temp. w/built-in "
The water temperature get to hign
Why the the temperature get too high
    Problem Solver:
  • 25 Answers
The F-22 wash tank heater is controlled by a thermostat that opens or close a relay located in the control panel on the right. the thermostat is located inside the machine next to the wash tank. the thermostat is fixed position and can not be adjusted. the temperature should be 170F max. The thermostat has a bulb attached by a wire. this wire is actually a tube and the bulb is filled with an oil that expends when heated. the bulb is inserted in a cavity in from of the wash tank. You can access this by removing the front panel. If the bulb is not in the cavity, it will produce alot of heat. if the "wire" is broken or just simply the thermostat has become defective than it should be replaced. Search by part number or description
Posted on Jul 15, 2014
SOURCE:
Changed out water pump and thermostat and vehicle runs high temperature what could be issue?
Reasons the Temperature Gauge Reads High
If the temperature gauge reads high, it could mean your engine is overheating. Another reason your reading might be high is you could be losing coolant. A small leak or evaporation may cause your radiator to slowly lose coolant. A third reason your temperature gauge reads high could be because the thermostat is broken. If this is the case, you may need a coolant temperature switch replacement. The last reason the temperature gauge could read high is because of a water pump, or water pump gasket failure. If the water pump is malfunctioning, it may need to be replaced by a professional.
What to Do If Your Temperature Gauge is High
If your temperature gauge is reading high, it means your car is overheating. This is a very serious matter and you should never drive an overheating car. If your car starts to overheat, shut off the air conditioner and open the windows immediately. If this does not reduce the overheating, turn on the heater as high as it can go. If this still doesn't work, pull over on the side of the road, turn off the engine, open the hood carefully, and wait until the vehicle cools down. Never open the radiator cap while the engine is hot - coolant can spray and burn you. Once the vehicle has cooled, take the car to a mechanic right away so they can diagnose the problem. Cars are especially susceptible to overheating in hot climates, like what's common in cities like Los Angeles, Phoenix, Las Vegas, or Atlanta.
The temperature gauge is an important tool in your vehicle that shows the temperature of your engine's coolant. Contact YourMechanic and have your car inspected for overheating if it reads too high, as this can cause serious problems...
Reasons the Temperature Gauge Reads Cold
On most vehicles, the temperature gauge reads cold until the engine has run for a few minutes. If the temperature gauge still reads cold after the engine has warmed up, the gauge may simply be broken. Another reason the temperature gauge could read cold is if the thermostat in the vehicle stays open. With the thermostat stuck open, the engine can be overcooled, causing a low temperature reading. If this is the case, the thermostat may need to be replaced.
Oct 28, 2017 | Cars & Trucks
Tip
Air To Water Heat Pipe Heat Exchanger
General Information
Air to water heat pipe heat exchanger is mainly to heat water using the hot air from heat recovery, it can be used for domestic water, water for boilers or production process. The exchanger is constructed using a partition in the middle to separate the exchanger, both sides are independently sealed. A single heat pipe can be replaced. While working the hot air flows from one side to the other side, the heat pipe absorbs heat. Meanwhile, cold water flows from the reverse side, the heat pipe releases heat, thus heating the cold water from the reverse side. The outlet temperature is not lower than dew temperature.
Field of Application
-feed drying
-cereals and oil processing
-chemical industry
Specification
Advantage:
-high heat recovery efficiency
-seldom temperature difference, fast heat starting, good isothermal
-the speciality of the heat pipe results in a high wall temperature, exhaust gas temperature can be reduced without reaching the acid dew point, avoid the corrosion of the equipment.
Core tube material: stainless steel, carbon steel
Fin material: aluminum, stainless steel
Tube/fin bond: extruded, high-frequency welding
Tube arrangement: staggered
Core tube external diameter: ?25
Core tube wall thickness: 2-3mm
Fin thickness: 0.4mm
Fin height: 12.5mm
Fin spacing: 3mm
Temperature range: 20~150?
Order Information
P/N Description: HP-XYZ-N
Note: X should be replaced into S, C
Y should be replaced into S, A
Z should be replaced into ET, W
N means the power needed
S-stainless steel
C-carbon steel
A-aluminum
ET- extruded
W- high frequency welding Air To Water Heat Pipe Heat Exchanger
on Dec 14, 2016 | Miscellaneous
Electric tank water heater is in attic. When outdoor temps are high it doesn't work. Why?
Hi Jan:
Really interesting............
A puzzle I've never encountered before.
I'm a retired Contractor and Building and Plumbing Inspector so can offer an answer based on experience.
- In hot weather, attics get REALLY hot.
- An attic is an unusual location for a hot water tank.
- A thermostat senses the temperature of the water in the tank and determines when it needs to be heated.
- I would be suspicious that in your installation, the temperature in your attic is higher than the "high limit" for your water heater.
To phrase it another way, since the attic temperature is really high, and the tank thermostat is in the attic, it "thinks" that the water is already at the required temperature.
The only real "fix" that I could suggest would be to locate the hot water tank in the moderated temperature area of the dwelling.
Hope this helps.
I would appreciate your letting me know by comment to this post if that is the problem.
Cheers, and thanks for the puzzle.
Apr 24, 2016 | Water Water Heaters
Loc error code Frigidaire frontloader
From the frigidaire site.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
P1298 eld voltage hign
P1298 Electric Load Detector (ELD) Circuit High Voltage.
Possible causes:
- Fuse.
- Wiring.
- ECM/ PCM
Mar 17, 2013 | 2004 Honda Civic
How can I check water temperature as I think it's too high
You can use a thermometer to check the temperature but if you are not able to set the temperature to a lower point it can be related to a faulty thermocouple. Remove the wiring to the element and the sensor and check or replace. click on : element
Jan 17, 2013 | Washing Machines
Kicks off on high side temperature
one of the thermostats has gone bad and it causes the reset to kick...
Check out this tip and also the other links to tips at the bottom of this one...
Electric Hot Water Heater Temperature Adjustment
http://www.fixya.com/support/r4656190-electric_hot_water_heater_temperature
heatman101
Jul 12, 2010 | RELIANCE ELECTRIC WATER HEATER
Tv says the temperature is too hign
In the rear of your set where you can see the lamp, there should be a cover with a filter on it, take the cover off and blow the dust off the filter and also the fan that cools the lamp. Some do not have a filter just air vents, in any case make sure all is blown out. Let me know for solution # 2 if this doesn't work !
Apr 28, 2009 | Zenith Televison & Video
Jet Tech Systems F-22 - Dishwasher, Door Type, high temp. w/built-in " Logo
63 people viewed this question
Top Jet Tech Systems Dishwashers Experts
Robert Marsolais
Robert Marsolais
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
